Unread 02-13-2013, 07:56 PM   #1
scott-wisc
Scott's Main Bath Remodel
So I'm gutting the master bathroom in my house and moving a couple of walls to increase the size. I'm installing tile on the floor and a tile shower using Kerdi. I need to patch a couple of areas of the 1/2" plywood then most of the 5/8" underlayment. Do I just use underlayment particleboard? Is 1/4" CBU okay for the floor? Can I build the mud preslope on top of the particleboard once the shower is framed?
Thanks, Scott
scott w
scott-wisc is offline   Reply With Quote
Unread 02-13-2013, 08:02 PM   #2
Lump
Lump's Avatar
Scott, the particle board needs to go and if you need to remove some of the bad ply then you may as well install a new layer of 3/4'' T&G plywood.....Assuming you checked the defecto calculator above.
Brad L. Lenz
NTCA Proud Member
Unread 02-13-2013, 08:08 PM   #3
5/8 plywood is the bare minimum with 16" OC joist spacing. If your joists are wider, you'll need thicker plywood. Use nothing less than CC grade plywood if you can find it. Round these parts BC plywood is a lot more common.
Unread 02-13-2013, 08:10 PM   #4
Lump
Lump's Avatar
Scott typically those builds were 1/2" plywood then 5/8" particle board over 16" on center 2x10's that spanned a bit to far.
Brad L. Lenz
NTCA Proud Member
Unread 02-13-2013, 08:33 PM   #5
PC7060
PC7060's Avatar
Scott,
Just went through these same issues (or similar). You can see what I did to strengthen the floor in my thread starting on page 4.(http://www.johnbridge.com/vbulletin/...=105151&page=4).
I would follow Brad's advice and rip all of the subfloor out and replace with 3/4 T&G. I messed around for a while trying to fix my bad floor before I did a full replacement. Also added joist sisters to level and strengthen the floor. The work didn't take that long and the structure is much stronger and ready for the CBU & tile
Good luck.
Unread 02-22-2013, 07:33 PM   #6
PC7060
PC7060's Avatar
Guess Scott has left the building.....
Unread 04-02-2013, 09:01 AM   #7
scott-wisc
Door Opening Size
I'm about to frame out the shower wall with the door opening in it. What should the finished width be? I won't be buying the door until next year, so I need to know what a common size would be, say for a 30"ish door.
Thanks, Scott.
scott w
Unread 04-02-2013, 09:28 AM   #8
Scott, buy the door now and make the opening the right size for it. Making a "30"ish" opening may require you to buy a custom door to fit. Buying a "30"ish" door now will allow you to make an opening into which it'll fit.
Either your shower subfloor or your bathroom subfloor is installed in the incorrect orientation.
Unread 04-02-2013, 10:51 AM   #9
Maniac979
Maniac979's Avatar
Scott, You might look at the Kohler shower doors sold at HD and Lowe's. These doors come in a range of widths with a couple of inches of adjustment for each width.
Ed
Maniac979 is offline   Reply With Quote
Scott's Main Bathroom Remodel scott-wisc Tile Forum/Advice Board 25 03-23-2011 12:52 PM
Scott's bath remodel Scott_V Tile Forum/Advice Board 46 10-04-2010 11:43 PM
Will's main bath remodel chassis Tile Forum/Advice Board 68 01-21-2008 07:42 AM
Main Bath Remodel TerryB Tile Forum/Advice Board 43 04-09-2007 04:18 PM
Main Bath Remodel Mickster Tile Forum/Advice Board 26 10-05-2006 04:32 PM
