Unread 02-03-2012, 12:12 AM   #1
Lethe
Kerdi Line drain question
Had a quick question on their line drain. I am looking at their price sheet.
kerdi-line.com/pdf/KL-PriceSheet.pdf
Do I need to order both the bonding flange AND a grate assembly to have a complete drain? Looking at the pictures the bonding flange looks like it is only a frame, is it actually the "stainless steel channel body" they mention in the description?
I'm interested in frameless tileable look shown on kerdi-line.com. I have roughly 28" wall to wall. Do I need to order item #KLV 60 E 60 AND item #KLC 19 EB 60 to achieve this? I'm horribly confused! Thanks for any help you guys can give me!
Eric
Lethe is offline   Reply With Quote
Unread 02-03-2012, 06:23 AM   #2
cwilde72
cwilde72's Avatar
Eric, as I understand it the lengths given are nominal. So for the 28" drain you would need a 30" opening. If all you have is a 28" opening then you would need to go with the 24" drain which would require a 26" opening. And yes, you will need to order both the frame and the grate to have a complete drain.
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Unread 02-04-2012, 05:43 PM   #3
Lethe
Thanks much!
Eric
Unread 02-04-2012, 05:56 PM   #4
Not sure what your total shower dimensions will be, but keep in mind it must exceed 900 sqin, the door opening must be at least 24", and personally, 28" is tight between shower walls. for the average person, that makes it tough to bend over and pick something up, or to wash all parts!
Kerdi Drain Question nokoni Tile Forum/Advice Board 14 02-01-2012 06:58 PM
Tub Drain Line Question LegoMyEgoLess Tile Forum/Advice Board 9 05-08-2008 07:14 AM
kerdi drain question dustpol Tile Forum/Advice Board 1 03-08-2006 09:22 PM
Kerdi Drain question Jason346 Tile Forum/Advice Board 2 11-18-2003 05:41 PM
Kerdi drain question robwub Tile Forum/Advice Board 2 10-11-2003 05:39 PM
