Newb tiling above shower
This is my first post although I have been reading this board thoroughly as I do belong to other boards and dont want to get flamed right away
I just took on a bathroom job (new room above my garage) and think I have worked myself into a situation. I have a couple of questions that I had trouble finding the answer to by searching. I have a 1-piece fiberglass shower unit that I wish to tile above, and around the front edge.
1. I made a mistake by installing the first piece of Durock wrong. I was initially going to use mastic until reading this board, now the back wall piece has the smooth side out.......is this a problem I can overcome? I hate to remove it as the other (correctly) installed pieces overlap the edges and it is all glued/screwed in place. Can I skim coat it first or put a sealer of some sort prior to thinset? I did install a 6 mil vapor barrier behind the durock and used proper screws.
2. The transition from the durock to sheetrock (outside of the wet area) is level as I used 1/2 board on both. I used the proper mesh tape for the durock, and taped the durock to sheetrock seam. I am mudding up to the transition seam. Once smooth, can I use thinset on the sheetrock after priming/painting? This will be for the small decorative trim tiles outside of the shower door. Is there a better prep for sheetrock than priming/painting for thinset?
I hope I explained my situation and thanks in advance for any advice.
Ron
