Unread 11-06-2009, 07:09 PM   #1
johntrent
Kerdi remodel drain
I got my first remodel drains this week & tried to use one today but there is a problem...no way to line any holes up or even drill new ones thru the metal ring - the ring is bigger than the standard clamping drain we see in this area. Anybody else tried these or had this problem?
John
johntrent is offline   Reply With Quote
Unread 11-06-2009, 07:15 PM   #2
The Kid
The Kid's Avatar
John, i thinks you may have the wrong adaptor for the particular drain you have, only problem I had was threading the bolts through the factory holes and lining them up.
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Unread 11-06-2009, 07:18 PM   #3
The Kid
The Kid's Avatar
http://www.johnbridge.com/vbulletin/...+adapter+video
Jeremy
Unread 11-06-2009, 07:26 PM   #4
johntrent
Jeremy - After seeing your pics I definitely think I have a different adapter - mine is bigger than yours
I sent pics to my rep and called my distributor but nothing was mentioned about different sized adapters. My impression was that it was a one size fits all.
I didn't lose much time over it though - went ahead and cut the old out & glued a standard kerdi drain until I could get an answer. I'll check with them both tomorrow.
John
Unread 11-06-2009, 07:32 PM   #5
The Kid
The Kid's Avatar
I think you got the commerical adapter, the residential one just came out, after using it, id rather just cut out the old anyway.
Jeremy
Unread 11-06-2009, 07:35 PM   #6
johntrent
Yea - I wondered about it being worth the effort. I've pretty much got the cuttung & glueing down to a tee -& think I feel better with the glued connection vs the clamped. But I am willing to give it a go a time or two before making a call.
John
Unread 11-07-2009, 12:30 PM   #7
custombuilt
That looks like the commercial 4'' adapter that andy showed us at schluter class-- Remember?
I'm glad you mentioned this cuase I am ordering an adapter for a shower I'm doing in 2 weeks and have to make shure i get the right one. Can't glue it in cause the plumbing was already pressure tested and inspected.
Jason W.
Superior Construction
Quincy, IL
Unread 11-07-2009, 01:06 PM   #8
johntrent
Jason - you are right I forgot about that until you mentioned it - glad someone was paying attention
I did talk to my distributor today and he confirmed they had ordered the wrong drain.
John
Unread 11-07-2009, 01:14 PM   #9
using a kerdi drain in a remodel BrendaS1 Tile Forum/Advice Board 28 07-03-2009 07:54 AM
Kerdi Drain - bottom part of regular drain golfnut_eh Tile Forum/Advice Board 7 11-30-2008 10:36 AM
Kerdi drain with cast iron drain pipe? madoka Tile Forum/Advice Board 5 04-30-2008 02:43 PM
Connecting Kerdi drain to cast iron drain pipe hopkibm Tile Forum/Advice Board 21 09-17-2007 11:33 AM
Difficult Kerdi drain connection vs. cast iron clamping drain alember Tile Forum/Advice Board 11 04-06-2004 04:40 PM
