Unread 11-12-2008, 01:13 PM   #1
TerryM
Ceramic tile to wood and concrete substrate
John,
I'm new to tiling and have a customer who has removed an old fireplace and hearth and wishes to fill the recess left with ceramic tiles [7" square x 5/16" thk.]. The area is approx. 6 ft x 6 ft and sits approx. 3/4" below the remaining floor [3/4" hardwood flooring]. The substrate is made up of approx. 25% wood underflooring and 75% concrete.
Since I need to keep the top of the tiles level with the top of the surrounding wooden floor, I have approx. only 7/16" of height to play with. What do I use to ensure a solid job when trying to tile over the mix of wood and concrete ?. The wood and concrete subfloor is basically the same elevation as each other.
Regards
TerryM.
TerryM is offline   Reply With Quote
Unread 11-12-2008, 01:31 PM   #2
Set backerboard over the plywood, then screed thinset on the concrete to match the height. Install an antifracture membrane across the joint, or plan a soft joint in the tile over the joint.
