12-29-2006, 05:18 PM
Granite, Quartz, and Tile Installer
Steve,
this is from ANSI A108:
A108.01 General Requirements: Subsurfaces and
Preparations by Other Trades — 2005 [New]
A108.01.2.3 Deflection
Floor systems, including the framing system and subfloor panels, over which tile will be installed
shall be in conformance with the IRC for residential applications, the IBC for commercial
applications, or applicable building codes.
NOTE - The owner should communicate in writing to the project design professional and general
contractor the intended use of the tile installation, in order to enable the project design
professional and general contractor to make necessary allowances for the expected live load,
concentrated loads, impact loads, and dead loads including weight of the tile and setting bed. The
tile installer shall not be responsible for any floor framing or subfloor installation not compliant with
applicable building codes, unless the tile installer or tile contractor designs and installs the floor
framing or subfloor.
Interior Installation of Cementitious Backer Units ANSI A108.11
— 1999 [Reaffirmed 2005]
A108.11.4.0.3 Support framing shall be designed for a maximum allowable assembly deflection of L/360
under all intended live loads. I couldn't find anything in ANSI about the L720 deflection requirement. The Marble Institute of America identifies L720 deflection for stone surfaces in their Stone Design Manual. I don't have a copy on hand to quote you chapter and verse.
Hope this helps.
Juan
__________________________
You are never too old to set another goal or to dream a new dream. - C. S. Lewis
