Unread 09-03-2005, 06:26 AM   #1
luellendahl
Smile curbless shower/almost
I am building a modest second bathroom (5x10) that will feature a walkin or curbless shower. 3'x5'. Room will be accessed by 2 converging pocket doors. My husband has Parkinsons disease. Although he can now walk...the probability of wheelchair use is somewhere around the corner. I am torn between a very short curb which I guess I could retro fit with some kind of angled inset later and a curbless shower. Curbless would make for a wetter more slippery floor now. The floor will be some kind of small matte mosaic. There will be a half wall (54" high) halfway down the 5' length.My husband pulls on things for support and I want to avoid glass doors and curtains. Could I create a curbless shower and simply place and seal a standard marble threshold to contain the water better? I know the shower floor area will be approx. 3/4 " lower than the rest of the floor. I like the look of a curb and the ability to keep the floor a bit dryer but I want to hedge my bets.
luellendahl is offline   Reply With Quote
Unread 09-03-2005, 07:00 AM   #2
muskymike
muskymike's Avatar
Hi there welcome. Do you have a first name we can go by? You could use the marble but then you have something to try to get a wheel chair over. If you use the kerdi system by Schluter you can do it with out the curb. Or some other waterproof membrane.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 09-03-2005, 07:26 AM   #3
luellendahl
forums WORK!!
Linda. Thanks for the quick response. This is actually amazing to me. I've actually never even used a forum before. I will reference that system when I talk to the next plumber, nice not to sound like a dummy! I have a contractor who did a kitchen remodel. and haven't talked to his plumber yet. I spoke to one local plumber who does a lot of work in our area. He wanted a fortune (so we won't be using him) but he persuaded me that a very short curb ( my original thought)with a pan was a bad idea and said that he would "vinyl" the whole floor area. Schluter looks better.Eugene's skills will be varied for a long time...so if I can convert to smooth at whatever point I need that will be perfect.
Unread 09-03-2005, 09:55 AM   #4
Hi Linda, a 3 x 5 shower is kinda small to be curbless and without a curtain. There will be alot of water out on the bath floor.
Is this on slab or wood sub-floor?
Unread 09-03-2005, 10:11 AM   #5
luellendahl
I have a double window that leaves 40" of wall space to the left and I thought that lining everything up would be visually pleasing. But I'm hoping that a half wall...starting at the shower fixture end...shoulder height...30 " long...could contain a lot of the splashing. On the inside its a great place for another grab bar and toiletry niche. I want to leave 30" free for one of those small shower wheelchairs...they are actually less than 24" wide. I want the space to feel open. I know that my space is a small for the concept, but I don't expect a sahara desert dry floor either. Think there's a minimum width that I should consider?
Unread 09-03-2005, 10:13 AM   #6
luellendahl
Forgot about wood or slab....right now it's a hardwood floor that they will cut into, so I guess wood is the answer. And I DO want to create a curb with
a semi-permanent marble threshold that I could remove when needed.
Unread 09-03-2005, 01:13 PM   #7
Hi Linda, Welcome aboard.
I've done a couple curbless showers with the Schluter Kerdi system. Both of them are a about 48 in. deep, though. I incorporate a sort of speed hump at the entrance that consumes about a foot.
As has been stated, though, with a wood subfloor it's possible to build a shower with no curb and no hump. It entails removing the subfloor and cutting down the joists to make room for the shower floor mortar.
I've also recently done a shower with a partial wall at the front. I built it from concrete blocks to gain stability. A frame wall would have to be anchored to the ceiling at the end.
Unread 09-03-2005, 03:55 PM   #8
luellendahl
Well that's impressive.
If I didn't have to eventually accomodate a wheelchair I would have handed your very thorough shower bench instructions to my general contractor. I AM getting several niches though and can hand him those pictures!
My half wall will be in front of the pocket of the pocket door. I can attach support to the door header...ceiling and floor...hope that's enough.
My space has other restrictions...it's on the second floor with an attic slope ceiling....22" flat then a roof angle. Even if I had wanted one of those handsome all glass showers it would have required a kinda weird angled door.
Maybe I should forget the whole curbless thing. Started looking up how to retrofit an existing shower for accessibility. There is something called a threshold ramp. Some are made of rubber , trimmable widths, and come in sizes up to 3" high. If I got two (manufacturer suggestion) I'd be able to handle a wheeled shower chair with a more standard shower. Is 3" sufficent height for the outside of a shower threshold? Maybe it could be even shorter? I'm also thinking that I could put a glass splash guard on top of the half wall to make it a sorta whole wall. Towel bar outside, grab bar inside
