Hi
I guess I should have found this board before but I'm glad I found you now
Here is where I'm at with my custom shower.
size is 5x6ft with a slopeing roof about 8ft down to 6ft, 2nd floor new construction, 11 7/8 joists with t&g plywood floor, walls and cielings done in greenboard.
I had a freind of a friend do the floor and as far as I know he does these professionally.
after reading the board, Im sort of concerned.
He installed a membrane colled "compu" somethingorother. looks like a blue sheet membrane. Installed about 10 inches up the green board in one piece. It is installed on the clean plywood then put in a mortar floor pretty thick maybe 3"-4" thick with a slope. the membrane is is caulked and screwed to a drain with a seperate place for the membrane and a screw in drain.
Question
1- is the membrane supossed to have mortar under it for a slope?
2- he says use wonderboard on the walls and ceiling and dont use screws below 6 inches .
3- am I supossed to tape and seal the wonderboard before tileing.
Maybe a few more ?'s
Thanks Bert
