Unread 05-19-2008, 09:24 AM   #1
RollTideFan
Kerdi Application Question
Hey Guys, Good Morning,
A couple questions for you pro's before I take on my tub suround. I'm now seriously considering Kerdi instead of traditional CBU method.
1. In everything I have read I am to stick the Kerdi directly to my sheetrock using UN-MODIFIED thinset - is this correct?
2. If I use UN-MODIFIED thinset sticking the Kerdi to sheetrock then, do I still use a LATEX MODIFIED thinset over the top of Kerdi to stick my tiles too? If so why unmodified in underneath Kerdi area and modified on top? I'm confused.
3. Should I use a sanded or non-sanded grout after tile installation? I have not decided on a tile yet, but hopefully someone can still answer this? Tile spacing will be 1/8".
Thanks Guys,
Torrey
RollTideFan is offline   Reply With Quote
Unread 05-19-2008, 09:31 AM   #2
Jeremy202
Kerdi will not be warrantied if you use a modified thinset but from what ive read here it wont harm it. I just finished my shower using a complete Kerdi system and used Megabond un-modified thinset by Laticrete under the kerdi and over the kerdi for the tiles and had no problems, and it does not leak.
As for grout, i had a 3/16 " spacing and used unsanded grout inside the shower and sanded outside the shower and it worked fine, but you may want to hear from a pro on this question.
Good luck on your project.
Jeremy
Jeremy202 is offline   Reply With Quote
Unread 05-19-2008, 11:15 AM   #3
Hi Torrey,
Jeremy has given you sound advice. Another good non-modified thin set is Ditra-set, if you can locate it. I use VersaBond, also. VersaBond is modified and does void the Kerdi warranty, but it works.
Unread 05-19-2008, 02:24 PM   #4
RollTideFan
Can I buy VersaBond at my local home-box store? Any idea of where to find Ditra-set?
Unread 05-19-2008, 02:28 PM   #5
VersaBond is sold by Home Depot. Don't know where you might find Ditra-set in Alabama. It's made by Bostik, though.
Unread 05-19-2008, 03:02 PM   #6
Woodturner
I am not sure which part of the state you live in but here is a list of places that carry it...These are the closest to me. Here is the link to bostik and you can search for the dealers and for products also...
http://www.bostik-us.com/index.asp?fa=home
Company ROBERT F HENRY TILE (HYDRO)
Address 4840 COMMERCIAL DR
Address HUNTSVILLE, AL 35816
City HUNTSVILLE AL 35816
Phone (256) 837-0500
Fax (256) 837-0528
Distance Approx. 16 Miles
Company ROBERT F HENRY TILE (C)
Fax (256) 837-0528
Company CARPET WHOLESALE SUPPLY
Address 3801 VANDERBILT RD
Address BIRMINGHAM, AL 35217
City BIRMINGHAM AL 35217
Phone (205) 849-8200
Fax (205) 849-8201
Distance Approx. 85.3 Miles
Company TRADITIONS IN TILE
Address 2548 BRANSFORD AVE
Address NASHVILE, TN 37204
City NASHVILE TN 37204
Phone (615) 269-9669
Fax (615) 383-2312
Distance Approx. 89.3 Miles
Company ROBERT F HENRY TILE (DURTL)
Address 119 45TH PLACE NORTH
Address BIRMINGHAM, AL 35202
City BIRMINGHAM AL 35202
Phone (205) 592-8615
Fax (205) 592-8625
Distance Approx. 90.6 Miles
If you don't have time to do it right the first time you sure will not have time to do it the second time.
Woodturner is offline   Reply With Quote
