Unread 03-15-2015, 01:46 PM   #16
MethowMojo
Tile Contractor
MethowMojo's Avatar
Dude! You're a wizard!
I am blown away at your concrete skills. And only 15 days? What an honor for you to get to do this project.
My hat's off to you sir!
Jim
"You can have it done RIGHT, FAST, or CHEAP." Pick two.
MethowMojo is offline   Reply With Quote
Unread 03-15-2015, 05:54 PM   #17
Jim Doane
Custom Masonry Contractor
So , The 1st day into this project I was informed that the 36 inch diameter bronze medallion , that is the center piece of the memorial may not arrive by the Feb 11th my deadline . ( The HOA / designer handled this piece of the project ) . I called their supplier to verify exact thickness of medallion and to emphasize it has to be exactly 36 inches in diameter as all tile / layout has been based on this most critical dimension. I than had water jet company cut me a exact 36 inch diameter template to use as a guide to set the first band of polished blue mica flaked porcelain. That problem temporary solved. Next I called Laticrete. Informed them of the project and my time restraints on completion. When I told them I had to install tile on fresh / green concrete in 36 hours there was a little bit of silence. The solution was 254 to set Stratamat , Stratamat , than 254 to set porcelain , Permacolor grout and Latisil for my three circular soft joints . Laticrete donated all materials no questions asked and they had it delivered to my local distributer in 48 hours. Only for Henry would I ever put on a fluorescent green t shirt
Jim
Jim Doane is offline   Reply With Quote
Unread 03-15-2015, 08:16 PM   #18
Tiger Mountain Tile Inc
This is a really interesting thread and I'm glad that you are letting us follow what's going on.
Nice new Laticrete shirt.
James Upton
Why you should NOT buy a newly remodeled home ~DIYTileGuy
Unread 03-15-2015, 10:02 PM   #19
dhagin
Great lookin work, thanks for lettin us follow along!
dana
Unread 03-18-2015, 05:46 AM   #20
Jim Doane
I installed the blue circular band of tile around the medallion template , stood back and looked at it and realized how will I lower a 110 pound 36 inch diameter circle medallion when my soft joint between medallion and tile is 3/16 ? Luckily I had a rare smart moment and realized the best solution was to take two tile out so medallion could be set safely and than set them back after.
Jim
Unread 03-18-2015, 08:04 AM   #21
mullet
mullet's Avatar
Pretty awesome.
chuck
my first Kerdi Shower
Unread 03-18-2015, 06:40 PM   #22
Gary K
Vendor
Gary K's Avatar
Nice work!!!
Picking them up and putting them down.
Gary
Gary K is offline   Reply With Quote
Unread 03-18-2015, 07:54 PM   #23
K_Tile
Member of Million SF Club!!
Nice work. I like doing waterjet jobs...its tile by numbers!
Unread 03-19-2015, 05:36 AM   #24
Jim Doane
Medallion arrives 3 days before deadline. Installed medallion, set the two missing blue tile and black siliconed my 3 circular band soft joints. Landscape crew did their install the day before the memorial event .
Jim
Unread 03-19-2015, 05:52 AM   #25
jcsa
Tile Contractor
Medallion
Very Nice Jim!!! You should be proud. Thanks for sharing from the beginning to the end. Hopefully you will receive a lot of leads with this project. Thanks again for your work.
John Cox
JC
Certified Tile Installer # 26
Cox Tile, Inc.
jcsa is offline   Reply With Quote
Unread 03-19-2015, 06:10 AM   #26
Jim Doane
I have one final set of pics to post but have to get to work.
Jim
Unread 03-19-2015, 08:02 AM   #27
Nice work !
Unread 03-19-2015, 11:15 AM   #28
Good work, Jim. I'd love to do a job like that some time.
Unread 03-19-2015, 04:22 PM   #29
mark11755
Old Guy
That is fantastic.
Mark
mark11755 is offline   Reply With Quote
Unread 03-20-2015, 05:20 AM   #30
dbol
dbol's Avatar
looks really good. Thanks for letting us watch.
doug
dbol is offline   Reply With Quote
dust deputy drwcal Professionals' Hangout 15 06-17-2014 04:14 PM
I've fallen into the travertine trap Joefilly Tile Forum/Advice Board 17 01-07-2014 11:29 AM
deputy doolittle RedRock The Mud Box 1 06-21-2010 03:11 PM
Procession for a fallen soldier HS345 The Mud Box 6 08-17-2009 09:11 PM
Deputy sherriff came calling yesterday muley Professionals' Hangout 17 03-02-2004 04:14 AM
