Unread 06-30-2014, 02:45 PM   #1
strichzwei
Scott's Master Bath Remodel
Lurker here with my first post, Hi!
I am a DIY'er in the midst of a complete bathroom gut. I am planning my first (traditional) shower pan build where there was previously a cultured marble insert.
The first problem I am running into, and hoping to get some advice from the forum, is the vent pipe. It is proud of the stud wall surface by about a ½ inch and I am not sure the best way to tackle the problem. The vent pipe was poorly placed when the slab was cast and then the reducer bushing has aggravated the situation on top of it being angled inwards somewhat. I am reluctant to shim the area as the wall is pretty flat. I plan on the entire 10’ wall (where it is now missing drywall in the picture) to be tiled (12x24) and cannot imagine shimming the whole wall.
One thought I had was to simply relieve the 5/8” cement board around the pipe (see photo of the cardboard “mock-up”). I think this would leave enough room for pipe/felt/liner and allow the tile to lay flat, but not sure how unorthodox this would be and if it would result in issues down the road.
Would love to hear your thoughts and opinions on how to do this right.
Scott
scott
strichzwei is offline   Reply With Quote
Unread 06-30-2014, 05:31 PM   #2
Welcome, Scott.
My first try would be to move that bushing down to the floor so my bump-out would be very minimal and may, if you're planning a traditional shower pan, be covered by your two layers of deck mud an won't interfere with your wallboard at all.
Unread 06-30-2014, 05:33 PM   #3
Lazarus
Lazarus's Avatar
Scott~As you said, you might be able to "relieve" the backerboard behind it. In addition, it might be possible to grind down the flange on the pipe, itself. There is plenty of "meat" on it and, that coupled with with the CBU removal just might get you to a "Flat Plane."
Laz...
Unread 06-30-2014, 05:50 PM   #4
Steve in Denver
Steve in Denver's Avatar
I'd put a nice long (4 feet isn't long) straight edge on the studs in several places and see how flat the wall actually is. If it's perfectly flat, shimming will be a cinch. The further from "perfect" it is, the more important it is that you shim it anyway.
Steve
Steve in Denver is offline   Reply With Quote
Unread 06-30-2014, 07:07 PM   #5
madmantrapper
I'd saw off the pipe close the floor and use a fernco there and at the point where it needs to 90. Flexible enough to eliminate the problem.
Paul
madmantrapper is offline   Reply With Quote
Unread 06-30-2014, 07:45 PM   #6
sancyk
I'm no plumber but would an inside pipe reducer exist for the pipes you have?
http://www.h2oco.com/online_catalog/catalog/k/k_2.htm
Chucky
sancyk is offline   Reply With Quote
Unread 06-30-2014, 07:58 PM   #7
Steve C
Steve C's Avatar
I'd try what Paul suggested.
Steve
Steve C is offline   Reply With Quote
Unread 07-01-2014, 01:51 PM   #8
strichzwei
Great ideas guys, thanks!
I think a combination of these will get me where I need to go.
Is anyone aware of a reducer that is inside 2" to outside 1 1/2", that would be a huge help!!!!
thanks,
Scott
scott
Unread 07-01-2014, 02:03 PM   #9
Pete1972
Jack of all trades, master of none
Pete1972's Avatar
I'm not aware of one made for DWV applications....perhaps for pools or irrigation (which I think is what Chucky's link takes you to). I'm not certain I'd go that route though.
If it were my project I'd try what CX and Paul suggested - relocating that hub as close to the floor as you can and having it get lost (if you will) in the base of your shower pan. If that didn't get me where I needed to be then I'd either shim the wall out and/or relief cut the wall substrate.
Pete1972 is offline   Reply With Quote
Unread 07-01-2014, 04:39 PM   #10
Scott, I used one of those bushing that you're looking for just a few weeks ago to plumb the drain for an icemaker. They're out there, you just may have to go to a plumbing supply house to get it.
Unread 07-19-2014, 08:58 PM   #11
strichzwei
Add blocking to 2x4 stud wall for stiffness?
Hello everybody, would appreciate some advice on my stud walls.
Everywhere you see studs will be tiled. The facing wall (with vent pipe) is an outside wall and has no sheathing. The silvery board you see is some sort of thermal cardboard and then outside brick, apparently this was OK back in '86 when the house was built (Austin, TX). The 2x4 studs go up about 10 feet to the window. I can push the studs in and out a bit and was wondering if there was a way to stiffen them up a bit. I will of course put insulation back in before I install 5/8" durock, but do you all think I should also put some blocking in - between 4 and about 6 feet up the wall?
Scott
scott
Unread 07-19-2014, 09:10 PM   #12
Tiger Mountain Tile Inc
I'm not a structural guy so I'll let other comment on that but you're supposed to have blocking around the base to the shower and it's not a bad idea to add some in at the seams of the cement board. 3'H; 6'H etc.
James Upton
Tired of bullnose tile trim? Here are 5 edge trim alternatives ~DIYTileGuy
Unread 07-19-2014, 09:52 PM   #13
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
That wall will stiffen right up with tile and grout on it. It wouldn't hurt to sister up some studs . Not sure that blocking will do that much. If it's a shower wall then maybe make it a tad stiffer. If it's just a tile wall that doesn't need to be water proof then I wouldn't bother with it at all.
Travis
It's just a clever handle.
Unread 07-19-2014, 10:42 PM   #14
PC7060
PC7060's Avatar
Extra studs are helpful if you want a stronger wall and to bring a bowed joist back in line. It's good to add blocking now for any point where you may want to mount a bar or fixture later.
Unread 07-19-2014, 11:20 PM   #15
dhagin
Both blocking and doubling the studs will help, but honestly, if you're really adding 5/8 Durock or drywall, then just that will stiffen that wall too. Lay the sheets with the long dimension across the studs and stagger the vertical joints by half the long dimension, and use screws and glue to attach them. A layer of plywood under the Durock/drywall is another option.
dana
Scott's master bath remodel Sbgamecock Tile Forum/Advice Board 11 09-28-2014 07:19 PM
Scott's master bath shower redo pscott1455 Tile Forum/Advice Board 8 07-05-2011 10:54 AM
Scott's Master Bath- Help! zooluk Tile Forum/Advice Board 58 03-01-2010 03:50 PM
Scott's Master Bathroom Remodel ScottP Tile Forum/Advice Board 6 03-19-2008 12:00 PM
Scott's Master Bath/(project 1) Scott_Francis Tile Forum/Advice Board 14 05-23-2007 08:08 PM
