Unread 02-27-2020, 09:50 PM   #1
nickelec
Shower floor
Hey tile experts what do you guys think about using this type of tile on shower floor. One of them is 3x9 glass tile and the other has a slight beveled edge to them I'm assuming the beveled edge is a no on tile shower floor
Sent from my SM-G965U using Tapatalk
nickelec is offline   Reply With Quote
Unread 02-27-2020, 10:07 PM   #2
First, that size tile on a typical, central drain shower will be nearly impossible to set without lippage without a very precise pan. Most pans end up slightly like a bowl...larger tile need four flat plane sections to not have excessive lippage. It might work on a linear shower with one flat plane.
Second, glass tile tend to be quite slippery, and larger ones even more so, so I'm not a big fan of that, either. The grout lines on a smaller tile mean you can conform to most pans, and those grout lines add friction.
Unread 02-27-2020, 10:11 PM   #3
nickelec
What do you think about the smaller size tile in the pic it's not glass
Unread 02-27-2020, 10:17 PM   #4
About a 4" tile on a typical pan is the limit you can set and have look good without 'folding' the planes. IF you do that, you need a grout joint along that fold, which may or may not conform to your desired look.
Unread 02-28-2020, 10:28 AM   #5
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
And FWIW, I encourage folks to stay under 2" sq. for floor, because it follows pan contour better.
My pans are always greater than 1/4" per ft. 'cuz I like that water to be exiting floor quickly...whoosh!
Peter
Concrete shower floor - barrier free - linear floor drain wcontractors Tile Forum/Advice Board 4 08-15-2017 12:32 PM
Marble Shower Floor - Mosiac tile floor wet underneath? Charlie Hesson Tile Forum/Advice Board 11 03-23-2014 05:41 PM
floor heating systems inside of shower floor pgc555 Professionals' Hangout 41 12-01-2013 06:58 AM
Need to replace a tile floor in shower but all concrete came out to dirt floor. HollandConstructionServ Tile Forum/Advice Board 11 06-25-2008 10:13 AM
Different installation rates for floor / shower walls & floor? kje Tile Forum/Advice Board 2 06-17-2007 03:02 PM
