Unread 01-05-2010, 03:14 AM   #1
mazi
restoring honed marble
The marble installed is honed Jerusalem Gold which is calcium based, it was beautiful with no veins visible. A year passes and many areas are showing lots of veins and it seems its protruding when touched. Some areas are even getting chipped. Im not sure what is the source of the problem, but I think its caused from humidity and moisture travelling through the marble.
1st question, How to test moisture in marble floors?
2nd question, What is the best way to restore the marble?
mazi is offline   Reply With Quote
Unread 01-05-2010, 04:45 PM   #2
Davestone
Florida Tile & Stone Man
Well need to know more,such as,is this a wet area,was there sealer applied,is this exterior,how long has it been installed?Raised veigns suggest to me excessive wear.Is there a harsh cleaning procedure?
http://Davestonestile.com
Unread 01-06-2010, 08:47 AM   #3
mazi
the area is interior, it has been installed for a year, no, its not a wet area, and the owner only cleans with water, furthermore, its sealed with a good water based sealer,from stone care international.
the veins started to appear, then grow in width, then open up.
Im sort of convinced that it is water evaporation but how can i prove that, is there a way to test moisture in marble floor?
Unread 01-06-2010, 10:17 AM   #4
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
Is there any way you could post pictures and do you know the composition of the floor, i.e. concrete slab (and age of), no/any moisture/separation membrane, setting medium, allowance for expansion etc.?
Sounds like it could be moisture, but it could be many or a combination of a few other things too.
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
Honed marble matman Cleaning, Restoration and Sealing 9 07-29-2007 11:05 PM
Restoring shine of marble agglomerate dnc0716 Cleaning, Restoration and Sealing 9 06-13-2007 11:45 AM
restoring cultured marble sink top keastman Cleaning, Restoration and Sealing 1 11-13-2006 02:53 PM
Restoring marble on foyer floor ATS Cleaning, Restoration and Sealing 1 12-08-2004 08:00 AM
Cleaning/restoring carrera marble tile? BarbFreda Cleaning, Restoration and Sealing 4 08-28-2004 07:21 PM
