Unread 11-03-2009, 10:38 PM   #1
lac1957
White stain on dark grout
After cleaning up dog urine accident, my dark grout looks white in areas now. I would like some suggestions for taking care of this problem. The tile is only 7 months old and the grout was sealed.
LA
LA
lac1957 is offline   Reply With Quote
Unread 11-04-2009, 06:24 AM   #2
Davestone
Florida Tile & Stone Man
Try some urine b gone or similar product to break down the enzymes.
http://Davestonestile.com
Unread 11-04-2009, 06:26 AM   #3
doitright
doitright's Avatar
Hi LA, Welcome!
What did you use for cleaning? It may be as simple as neutralizing your cleaning product. More details please.
John Koessler
Unread 11-04-2009, 06:49 AM   #4
lac1957
Water and vinegar to start; then a couple of different cleaning products with a toothbrush on the white areas, 409, then Kaboom. Not much if any improvement.
LA
Unread 11-04-2009, 11:14 AM   #5
doitright
doitright's Avatar
Hi LA
For starters, try ammonia and water (3 parts water to 1 part ammonia). Allow to dwell about 5 minutes, agitate (with brush), rinse.
John Koessler
Unread 11-04-2009, 07:36 PM   #6
Seattle Tile Cleaning
You might wanna consider colorsealing your grout.
Troy
Seattle Tile Cleaning is offline   Reply With Quote
Unread 11-04-2009, 07:50 PM   #7
doitright
doitright's Avatar
Hi Troy
That's an excellent recommendation for people who have pets!
John Koessler
Unread 11-07-2009, 02:13 PM   #8
SABoyt
Tile, stone and grout cleaning and restoration
SABoyt's Avatar
I don't think you will be able to clean that back to black. It typically is not a question of discolored but loss of color. The urine will eat through the clear sealer and when left sitting on the grout will remove the pigmentation. Clear sealers only provide you with a little bit of time to clean up the spill or urine in this case. It does not prevent penetration of the grout, in this case, for more than 15 minutes probably. Colorseal! That will provide you with a topical coating that protects the grout and prevents the urine from reaching the grout totally. But before you do, be sure to use something to neutralize the odor. The odor comes from the bacteria that eat the urine. As they die off, they produce an odor. The UR-Gone or some other similar product will take care of that.
Steve
www.HSSflorida.com
Cleaning and Restoration Services - HSMPA Certified Master Cleaner and Instructor
TMTrecovery.com
New and used Truck mounts
Cleaning and Sealing Trainer
ColorClad™ Premium ColorSeal Distributor
SABoyt is offline   Reply With Quote
Dark grout turning white, ceramic shower tiley Tile Forum/Advice Board 9 02-27-2013 12:20 PM
Why would grout start dark come out white? flazoom Tile Forum/Advice Board 4 11-02-2009 06:27 AM
Dark grout turning WHITE!!?!?? esc Tile Forum/Advice Board 5 12-24-2008 10:53 AM
cleaning white powder out of dark brown grout jenca78 Cleaning, Restoration and Sealing 3 09-21-2008 01:40 PM
Dark Vinegar Stain on Grout MelissaE Cleaning, Restoration and Sealing 1 10-12-2004 05:33 AM
