Unread 09-20-2008, 07:28 PM   #1
jenca78
cleaning white powder out of dark brown grout
I have sheetrock powder that I cannot get out of dark brown grout. I have tried scrubbing with basic soap and water, but it's not getting it all out.
Are there any cleaning products or techniques that will fix this problem? I really don't want to put more grout over what I already have.
jenca78 is offline   Reply With Quote
Unread 09-20-2008, 08:05 PM   #2
Davestone
Florida Tile & Stone Man
One of the problems with sheetrock dust is the particles are so tiny they imbed into surfaces and are difficult to remove.Typically a dish soap and water,one that produces a lot of bubbles,a grout brush to dislodge it, then a good wetvac will work pretty well. As a distant second an acidic cleaner and said grout brush and wetvac,vut i would use the first idea first.
http://Davestonestile.com
Unread 09-21-2008, 11:33 AM   #3
doitright
doitright's Avatar
Hi Jenca, Welcome!
I agree with Dave. I have also found using a tile & stone specific neutral pH cleaner (mixed to a stronger solution) and a good grout sponge, also help dislodge those fine particles (over a brush). The wet vac with a crevice nozzle will also help.
As always, TEST first.
For more aggressive cleaning you could try Prosoco's Tile & Grout Cleaner
John Koessler
Unread 09-21-2008, 01:40 PM   #4
jenca78
thank you so much!
