Unread 09-10-2014, 01:55 AM   #601
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Well my original Dewalt from 2008 that was rebuilt once finally died again.
The 2nd one from 2012 is doing fine.
I may look into repairing my 2008 saw again but I got my money's worth out of it and needed another saw right away.
I have a Felker XL250 sitting in my shop but hard to go back to it after using the Dewalts for a few years.
A local tool supplier had the Dewalt in stock and on sale.
Almost looks too pretty to use-
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 09-10-2014, 04:51 AM   #602
jondon
jondon's Avatar
Isaac yes they all look too perty when they are new. I am on my second one I bought little over a year ago. Here is how it looks now........
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 12-01-2014, 06:19 PM   #603
Autoplay
Tile Setter
Dewalt tile saw hex wrench
I purchased a Dewalt tile saw....and it comes with two hex wrenches,along with a stamped,box wrench for the nut,holding the sawblade.
My question is this......the bigger of the two hex wrenches......is there a place/keeper on the saw etc,to store it? There's a keeper place on backside of saw,to store the box wrench,along with the smaller hex/allen wrench. I saw no place on saw etc,to store the bigger hex/allen wrench.
Thx
Rich
Unread 12-01-2014, 07:06 PM   #604
Tiger Mountain Tile Inc
I think the big one is the one that you use to put it together. I wouldn't think that you'll ever need to use that one on the job. The other two have a place to store them on the saw because you'll need them for jobsite adjustments and to change the blade.
Jim Upton
DIYTileGuy
Unread 12-01-2014, 07:52 PM   #605
Mine came with two ??
Unread 12-01-2014, 11:07 PM   #606
studderin
I just keep the alen that donst have a molded spot, just wedge it behind the wrench for the blade nut. been fine keeping it there for years.
John
studderin is offline   Reply With Quote
Unread 12-01-2014, 11:56 PM   #607
RJW
Ryan Willoughby
RJW's Avatar
The other day my helper called me in saying that when turned on a 45 the blade was hitting the tray. After investigation I found a little crack in the housing that throws my blade out of square. I can adjust for straight cuts, but my miters are no longer true 45's. Should I try to have it rebuilt or is it a waste of time? Saw is about 5 years old and has put in 40 hour weeks for the most part.
Ryan
http://marintilestter.com
RJW is offline   Reply With Quote
Unread 12-02-2014, 01:18 AM   #608
jwmezzanotte
jwmezzanotte's Avatar
Get a new one IMO
I need to do the same. The motor on mine has been screaming all year. A matter of time. I need to get my new one on order though, Im going to burn this one right up.
Unread 12-02-2014, 08:43 AM   #609
HS345
Tile Contractor
HS345's Avatar
Kinda sucks that these saws aren't a little more heavy duty.
The name's Greg
Unread 12-02-2014, 11:24 AM   #610
5 years x 50 weeks a year x 5 days a week = 1250 days x 4 hours a day = 5000 hours. (you do turn it off between cuts)
A new saw is $800 (you can salvage your old stand) $800 / 5000 hours = 16 cents per hour.
That's one of the lower costs relative to your overall costs per hour. Buy a new saw, save the old for parts and don't look back.
Unread 12-02-2014, 12:58 PM   #611
Swedes Tile
Swedes Tile's Avatar
I get a slight curve in almost every cut now, is this blade wonder or is it in the tray? And it seem like it always wants to chip the right side cut at the end of the cut.
Swedes Tile is offline   Reply With Quote
Unread 12-02-2014, 01:33 PM   #612
Lazarus
Lazarus's Avatar
Sounds to Moi' that the blade is worn more on one side than the other. You could try cutting several cuts on a firebrick or old, dried morter to "dress" the blade and expose more diamond cutting surface. If that doesn't work, the blade is probably shot.
You can check the integrity of the saw by laying a framing square next to the blade, square to the stop and moving the tray all the way up and back. If the saw is off, you'll see a gap widen/narrow as you do this. Oh yeah....with the saw OFF, eh?
Laz...
Unread 12-02-2014, 11:28 PM   #613
Northmen
"Kinda sucks that these saws aren't a little more heavy duty"
Seems like these saws end up in the bone yard or landfill after a few years of heavy use.
I have a metal body Skil "made in USA"saw that still cuts like butter.The new norm is plastic disposable power tools.
Steve
Northmen is offline   Reply With Quote
Unread 12-03-2014, 06:52 AM   #614
HS345
Tile Contractor
HS345's Avatar
I have seen it time and time again with the Dewalt wet saws. And the last couple of years on them is not a great experience. I have always contended these saws are waaaay under powered. I have to say though, when they are new they are a pleasure to work with, you can do things with them other saws just can't do. Just wish they would make them a little more powerful, and heavy duty.
I personally have never owned one, but have used them a number of times.
The name's Greg
Unread 12-03-2014, 08:41 AM   #615
Sad things have turned out that way. I still have some tools that were my father's from back in the 70's, and they still work fine. Tools nowadays last 3-4 years and they're trash.
Usually, you do get what you pay for, but I agree that the Dewalt tools seem to be a little overpriced.
