Unread 02-11-2020, 01:03 PM   #1
Jdileo13
White film on stone shower floor after cleaning. Help!
Cleaning lady used 409 to clean our stone floor in our shower. It has since turned white when it is dry. It disappears when it is wet. What can I do to resolve this?
Jenn
Jdileo13 is offline   Reply With Quote
Unread 02-11-2020, 02:30 PM   #2
speed51133
Looks like it was acid etched.
You can buy an "enhancing stone sealer" to give it an all dark wet look. That's about it.
https://www.lowes.com/pd/Miracle-Sea...hoC_WoQAvD_BwE
Unread 02-11-2020, 06:34 PM   #3
Welcome, Jenn.
I can't find any indication that any of the 409 cleaners is acidic, but perhaps Mike will tell us how he knows about that.
Which of the 409 products was used?
Unread 02-11-2020, 06:49 PM   #4
speed51133
It's actually fairly basic.
http://www.cleanersolutions.org/inde...product_id=744
Pretty sure that will still etch the stone
Unread 02-11-2020, 07:12 PM   #5
I've never heard of an alkaline product etching stone.
Seems more likely that something like the 409 cleaner might leave some sort of residue, but I'm not familiar with that being a problem, either.
Perhaps one of our stone gurus will have a clue.
Unread 02-11-2020, 08:18 PM   #6
speed51133
https://www.granitegold.com/how-high...cause-etching/
Unread 02-11-2020, 09:03 PM   #7
kanderna
Tiling Noob
Sounds similar to an issue that we had years ago when we used some Lyson 4-in-1 cleaner:
https://www.johnbridge.com/vbulletin....php?p=1058518
We scrubbed a couple times with a mild Dawn/Vinegar/Water solution with limited success. We ended up buying another cleaner/solution (I forget the name), but we drug our feet and ended up not using it. The good news is that the white film disappeared, but it took a long time. Hopefully you can find something if you're less patient than us!
kanderna is offline   Reply With Quote
Unread 02-17-2020, 12:19 PM   #8
speed51133
just in case the OP comes back, I would like to know how/if this was resolved.
Shower Floor Tiles White Film/Haze jcress Cleaning, Restoration and Sealing 9 10-31-2019 12:34 PM
White film on new shower floor Stepane Cleaning, Restoration and Sealing 5 06-21-2017 04:24 PM
Suggestions on cleaning soap film offa rough slate shower??? claycarson Cleaning, Restoration and Sealing 12 11-06-2016 12:23 PM
Cleaner left white film on tile shower floor... kanderna Cleaning, Restoration and Sealing 7 02-23-2011 12:50 PM
white film on grout beth42 Tile Forum/Advice Board 4 03-22-2003 11:04 AM
