Unread 01-27-2020, 01:18 PM   #1
Silva1992
Help!! Water Marks on Polished Porcelain
Hi my name is Rafael Silva. I own a tiling company. We are having a problem i can find the solution for. We installed a 23'x 23' room of polished porcelain. Installation and grout is perfect. We only have a problem with "water stains" on most of the tile. The stains do not come out!. We have tried everything possible. We did use a little bit of muriatic acid dilluted into water(2caps for 5 gallon of water). general contractor is blaming it on the acid. I just can't see it being the acid as i have used it to clean tile for years, i have never had this issue. Has anyone here ever had this issue? If so do you know any solution other than ripping it up? I've tried pouring straight acid into a loose tile and the reaction did not happen!. Thank you in advance for anyone that takes their time to reply!
Rafael
Silva1992 is offline   Reply With Quote
Unread 01-27-2020, 03:00 PM   #2
speed51133
Why would you ever use muriatic acid??
That is so corrosive on everything, even if the liquid doesn't contact, the vapor will.
When you poured straight acid on a time, how long did you let it sit?
I'm sure the contractor is correct, that it is acid etched.
Only solution I can think of is a floor buffing machine and using a Polish compound.
Unread 01-27-2020, 10:30 PM   #3
My first go-to on porcelain would be vinegar and water 50/50, and if that didn't work, sulfamic acid crystals, after the grout is about ten days old.
Then I might try a magic eraser.
But whatever I try, I would test on a small, inconspicuous spot first.
Unread 01-28-2020, 01:09 PM   #4
Dave Gobis
da Man!
Dave Gobis's Avatar
Where is the tile from? That looks like some nano wax problems I have seen.
Something that is acid etched looks like a pineapple. That looks more like mineral deposits from watermarks.
Unread 01-28-2020, 02:30 PM   #5
speed51133
https://www.youtube.com/watch?v=vmX7SO6jKz8
Removing water marks from hearth cwolcott Cleaning, Restoration and Sealing 13 11-12-2018 07:10 PM
water marks in Marble timothy89 Cleaning, Restoration and Sealing 13 07-27-2011 12:44 PM
Polished Marble grout haze marks non-sealed kimgilliam Cleaning, Restoration and Sealing 1 11-25-2009 09:02 PM
Polished trav with "water marks" Buck Cleaning, Restoration and Sealing 13 08-27-2006 07:29 AM
Water marks in grout gchrisf Tile Forum/Advice Board 2 08-19-2005 07:52 PM
