Unread 12-16-2019, 12:03 PM   #1
tstex
buffing marble
Hello to all,
Is this the forum to discuss how to buff-out an off-white marble? I believe the sealer is gone and now the luster/shine is gone. From an angle, you can see what looks like "hard-water-stains".
My goal is to buff out the water-marks, then use a sealer that will protect the surface from further spotting.
thank you very much,
tstex
Tom
tstex is offline   Reply With Quote
Unread 12-17-2019, 09:13 AM   #2
Hi Tom,
When you say "buff" do you mean with a very soft pad by hand, or do you mean a machine. If machine I wouldn't. I think I would use a stripper that contains no acid and then reseal. I really not a stone guy, but I know that marble is delicate.
Unread 12-25-2019, 09:05 PM   #3
If it was cleaned with an acidic cleaner then the dull areas are etched. You would need to polish it out with a floor machine. Unless you have experience with doing that, I'd talk to a restoration company.
Unread 12-30-2019, 02:43 PM   #4
CRB
Tile, stone and mosaic installer
CRB's Avatar
Not really going to work. Requires 'drawing' the mark or stain out - various methods both traditional and modern product based you can look up or buy.
To then make it more reflective again and if not getting a professional to do the job then a 're-crystalizing' product will do an improvement job. [Clean it all then test a section first!!]
All depends on value of the floor to you / owner and if it is meant to be a full scale refinish or a maintenance tidy up.
Simplest of all to start is a marble product cleaner followed by a daily-use type marble maintenance wash-on product is my advice and see how it looks then. Not too much expenditure on those items and no damage to stone likely.
CB
Colin Barber Tiling Co.
In Christchurch New Zealand. From London UK
CRB is offline   Reply With Quote
Buffing scratches? emiliewasmyeve Tile Forum/Advice Board 1 07-12-2016 02:59 PM
carrara marble mosaic meets denim buffing wheel VinR Cleaning, Restoration and Sealing 5 04-17-2014 10:11 PM
Buffing Travertine Edges ? JHoward Cleaning, Restoration and Sealing 3 08-06-2010 06:32 PM
they want to use a buffing machine!! flipmick Cleaning, Restoration and Sealing 5 12-20-2007 03:51 PM
Buffing granite jjstours Cleaning, Restoration and Sealing 3 05-16-2005 06:26 AM
