Unread 10-20-2013, 10:17 PM   #1
Audrey
Kitchen backsplash grout and sealer advice
The grout space of our kitchen back splash varies a bit between 1/8" and 1/16". Is it okay to us sanded grout for this application? Do we have to worry about shrinkage issues with non-sanded? It is only 6 inches high but 21 feet in length.
We are looking for opinions on what color grout to go with? Perhaps a grey that is very close to the tile color?
In the past we have had issues with grout not being what the color should have looked like. Is this our error in mixing it? Are there certain brands that are more true in color?
What is the best substance to put into the space between the counter top and the start of the tiles?
Thank you in advance
Audrey
Audrey is offline   Reply With Quote
Unread 10-21-2013, 02:01 AM   #2
Lazarus
Lazarus's Avatar
A gray, close to that color works fine. Your choice there. Anything under 1/8" is going to requite an unsanded grout...however, a good option is Quartzlock II, available from tile stores such as Dal Tile or Fusion Pro, available from some Home Depots (although not all).
The area from the counter to the bottom row of tiles is different~you want to use a color-matching silicone caulk there as the differential from the horizontal to the vertical will invariably move somewhat and grout will crack if placed there....
If you have trouble finding a color-matched silicone, these folks can match it for you. http://colorriteinc.com/color-rite
Laz...
Unread 10-21-2013, 06:47 AM   #3
MDtile
Look into Customs "Prism" grout. It will solve both of your worries, as it is rated for 1/16"-1/2" joints as well as having extremely consistent color and exact match to sample chips
As Laz said, you need to caulk between the tile and the countertop.
MDtile is offline   Reply With Quote
Unread 10-21-2013, 12:14 PM   #4
Audrey
Thank you. I saw the Prism grout at the tile store and I see that I can get the QuartzLock at my local Home Depot.
I'll check them both out.
Cheers
Audrey
Unread 10-21-2013, 04:08 PM   #5
You might also want to check into the pre-mixed Fusion Pro grout from CBP. Its our go to grout, will not scratch or shrink. Its also stain proof and never needs sealing.
Unread 10-21-2013, 09:26 PM   #6
t2jeff
How did you finish the top of your backsplash? Is that a Schluter jolly profile?
Jeff
t2jeff is offline   Reply With Quote
Unread 10-29-2013, 07:25 PM   #7
Audrey
I had to look up the jolly profile to see what it was, and yes it looks the same as that but it is not the Schluter brand. Can't seem to see a name on it, I got it at my local tile store. The colour is titanium, has a very nice modern look to it.
Audrey
Kitchen Backsplash Advice KFINN59 Tile Forum/Advice Board 5 01-23-2012 12:43 PM
need kitchen backsplash advice dlhPacific Tile Forum/Advice Board 4 12-22-2011 04:15 PM
Kitchen backsplash advice Dan_H Tile Forum/Advice Board 2 08-19-2011 08:38 PM
Mosaic Kitchen Backsplash need grout advice Jakalin Tile Forum/Advice Board 5 01-28-2008 11:24 PM
Newbie with Kitchen Backsplash Sealer ?'s cbcoke Tile Forum/Advice Board 7 11-26-2003 09:35 AM
