Unread 09-07-2014, 09:24 AM   #1
davem
davem's Avatar
USG enters private label agreement with Powerhold
Here is a press release from USG I though might be of interest.
USG Releases Private Label Floor Prep Products Under Powerhold Brand
Nation’s largest flooring accessories distributor network to carry five USG floor prep products
CHICAGO—Sept. 4, 2014—USG Corporation (NYSE: USG), a leading manufacturer of high-performance building products, has entered a private-label agreement with Powerhold, the largest flooring accessories distributor network in the country. With the advent of this new partnership, USG’s distribution network in North America will be greatly expanded by the distributors represented by the Floor Covering Distributor Alliance (FCDA).
“The private-label agreement is a tremendous milestone for USG Tile & Flooring Solutions,” said Scott Crandall, national account sales and business development manager at USG. “It will provide us with an opportunity to serve the largest flooring accessories distributors in every market across North America.”
USG’s Powerhold products will be exclusively available to Powerhold’s vast network of flooring distributors. In addition, distributor members will have not only the best value products, but also an experienced team that is second to none.
“The Powerhold Brand, through the hard work and dedication of our distributor partners has become a recognized and respected brand in the floor covering industry,” said Dan Lee, president of FCDA. “We are thrilled with the expertise and support we have received in working with USG to further develop the Powerhold floor preparation line of products.”
“The FCDA strives to provide its distributor members with the best products in the market. Our partnership with USG, a demonstrated leader in the flooring industry, allows us to not only provide the best products, but the best in support as well,” said Jeff*Brugman, executive director, FCDA, Powerhold.
The five Powerhold products covered by the private label agreement include: Powerhold™ 850 Fast Finish Patch & Skim Coat;*Powerhold™ 650 NE Patch Plus;*Powerhold™ PC-5K Self-Leveling Underlayment; Powerhold™ LP-4K Self-Leveling Underlayment; and Powerhold™ 900P Primer.*
Offering 10 percent greater coverage than competitive products, Powerhold 850 Fast Finish Patch & Skim coat is an innovative, trowelable, cementitious floor patch that can be used on most interior floors including concrete, wood subfloors, and tile. Incredibly smooth and easy to work with, this floor patch also makes for an easy application process.
Versatile and trowelable, this floor patch is designed for interior use over concrete and wood subfloors. The polymer-modified, cement-based patching compound is ideal for renovation projects and provides a smooth surface for accepting floor coverings. No priming necessary, Powerhold 650 NE Patch Plus is easy to mix and apply, and is fast-drying; floor coverings can be installed in as little as one hour after set.
As a high-strength Portland cement-based underlayment, Powerhold PC-5K Self-Leveling Underlayment is ideal for interior use over concrete. With compressive strengths at a minimum of 5,000 psi, Powerhold PC-5K meets the requirements of ASTM F-710 “Standard Practice for Preparing Concrete Floors to Receive Resilient Flooring.” The fast-setting and application process also allows for return of light trade traffic within 24 hours and it can go from featheredge to 2 in. thicknesses.
Powerhold LP-4K self-leveling underlayment is a low-prep, versatile, high quality cementitious floor underlayment for interior use in light-commercial and renovation construction. With an exceptionally smooth, crack-resistant surface, Powerhold LP-4K self-leveling underlayment accepts a variety of floor coverings and helps to maximize sound isolation between floors/units.
Powerhold LP-4K can be easily applied over wood and concrete subfloors at a thickness of up to 3 in.; over non-water-soluble adhesives (on concrete only), and in radiant heat installations. Offering high compressive strengths (approximately 4100 psi) at low thicknesses, it is fast-applying and fast-setting; and can be walked on just 2 hours after installation, allowing for the return of light traffic.
Powerhold 900P Primer is a high-solids sealant that can be diluted with water to prime highly porous concrete, precast concrete, APA-Rated exterior glue plywood and OSB (oriented strand board). The primer may also be used as a sealer for Powerhold LP-4K self-leveling underlayment to enhance the bond between the underlayment and the floor-covering adhesive. With low odor, the Powerhold 900P Primer is mildew resistant and won’t stain a finished floor.
For more information visit www.Powerhold.com.
About USG Corporation
USG Corporation is a manufacturer and distributor of innovative, high-performance building systems through its United States Gypsum Company, USG Interiors, LLC and L&W Supply Corporation subsidiaries and its USG Boral Building Products joint venture. Headquartered in Chicago, USG Worldwide operations serve the commercial, residential, and repair and remodel construction markets, enabling our customers to build the outstanding spaces where people live, work and play. *USG wall, ceiling, exterior sheathing, flooring underlayment and roofing systems provide leading-edge building solutions, while L&W Supply branch locations efficiently stock and deliver building materials throughout the United States. USG Boral Building Products is a leading plasterboard and ceilings joint venture across Asia, Australasia, and the Middle East.**USG and its subsidiaries are proud sponsors of the U.S. Olympic and Paralympic teams and the Canadian Olympic team. For additional information, visit www.usg.com.
About Powerhold
The Powerhold brand was established in 1999 by a group of the largest floor covering supply distributors in the world. Known as the F.C.D.A. (Floor Covering Distributor Alliance), these wholesale distributors sell all of the products needed to install any type of flooring imaginable. In some instances, they sell the actual flooring. Visit www.Powerhold.com for more information.
davem is offline   Reply With Quote
Unread 09-07-2014, 08:12 PM   #2
Any of y'all have experience with any of those products? I'd never heard of Powerhold until this press release.
Unread 09-08-2014, 03:18 PM   #3
probably for laminate and vct guys and nothing to do with tile.
Unread 09-08-2014, 04:07 PM   #4
No, if you look on their site, Brian, they've got bonding mortars and patching compounds and SLC and such for ceramic installations, too. But not anything I've ever heard of. Say they've got eight stores in Texas, one of which is in San Antonio.
Unread 09-08-2014, 07:16 PM   #5
scrandall
Scott Crandall
scrandall's Avatar
Powerhold Members
Powerhold is a buying group or alliance of large floor covering supply distributors--know as F.C.D.A. (Floor Covering Distributor Alliance). They primarily sell products used to install all types of flooring, including tile installation materials. In addition to their own private labeled products, they carry products from many other manufacturers, including USG. You may recognize or already buy from some of the members, listed below:
Advanced Flooring (Canada)
Big D
Bixco
Blakely Products
Brolain (Canada)
Cronin Company
FISC (Canada)
Grosvenor
Hank's
Jer-And
L Fishman
McKenna (Canada)
MJS Flooring (Australia)
Pacific Rim (Canada)
Patriot
Professional Flooring Supply
Shamrock (Canada)
Space Flooring-CMH
Tom Duffy - BR Funsten
Scott Crandall
USG Substrates and Specialty Division
www.usg.com
scrandall is offline   Reply With Quote
Unread 09-08-2014, 08:46 PM   #6
never heard of any of those names either.
Unread 09-08-2014, 08:51 PM   #7
Even more interesting, Scott. If I harken back to when I was doing new residential construction I still don't recognize anybody on that list.
'Fraid I'll just hafta take your word for this bein' a good thing.
Unread 09-08-2014, 11:35 PM   #8
ded dux
ded dux's Avatar
I didn't really notice them till about 10 years ago, mostly carpet tools and supplies from what I've seen. They have some adhesives but mostly lower end stuff. I've only seen their products at Cronin Co.
Don
ded dux is offline   Reply With Quote
Unread 09-09-2014, 12:04 AM   #9
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
I think most of us tile contractors avoid 'flooring stores' when possible where those products are likely sold.
Those are the places that let carpet layers set tile
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 09-09-2014, 01:01 AM   #10
ded dux
ded dux's Avatar
Around here you go to those places or the box stores. Kerdi, ditra, ditra heat, Kerdi board, ardex 8+9, the usg waterproofing system, and a whole host of other tile supplies are sold at Cronin here, T&A has the laticrete side and some customs products like FusionPro. There are also 2 small tile specific stores 1 I frequent and the other I need to visit, but both those stores also sell to the public, I don't believe Cronin or T&A does.?.
It's kind of interesting seeing this thread about powerhold products since my reference to carpet tools was strictly from seeing them n Cronin, but gundlach which also seems carpet/vinyl tools has their own line of tile saws. Either way it is good to see more products coming out in the tile industry to create competition, I would guess my local Cronin will have a seminar for these products in the future, which would be nice.
Don
Sealer longevity vs. label info shredder Cleaning, Restoration and Sealing 4 07-05-2012 12:06 PM
