Unread 03-22-2019, 04:48 PM   #1
432Meyers
Shower window flush with framing
Hi Everyone,
Thanks for you willingness to advise and brainstorm.
I'm working on a bathroom with a vinyl replacement window to be installed in the shower. To waterproof it I'm thinking of prepping the old wood window frame (the "rough opening" for the new replacement window) with some type of traditional rubber with adhesive, paint, or other waterproofing (any suggestions?) to send any water that gets in the window to the exterior. I read some suggestions to wrap kerdi membrane into the "rough opening" before installing the window, but seems to me like another type of waterproofing here would be more suited for wood than kerdi and that wrapping kerdi over a slope toward the shower on the inside of the house and then under the window on a slope away from shower on the exterior of the house might be problematic.
After this I was going to use kerdi membrane over cbu on the shower surround walls, wrapped into the window recess and kerdi fixed to the vinyl window frame. The main issue is that the vinyl window frame is just about flush with the wall framing.
Do you all have experience with this?
The sill extends into the room about 1.25" from the window frame. Is this sufficient for a thin strip of cbu? I could fur out the window wall, and even use two layers of cbu for that matter, so that the wall makes a nice 90 degrees with the end of the window sill. What recess amount is ideal to try to achieve with the aim of tiling right up to the vinyl window frame? I see that there exists pencil tile trim that I could use here, or perhaps a quarter bullnose type tile, or even a Schluter edge trim?
I was also thinking of nixing the recess, cutting the wooden window jamb as flush as possible with the vinyl frame, installing a single plane of cbu up close to the window frame and trimming the window with some simple pvc molding. I just can't picture how to waterproof the window frame/cbu junction well.
The picture shows a replacement window installed (I'm going to do it again because there is a weld split in the vinyl frame).
I'm also going to see if I can use this window in a different part of the house, so that maybe I can make the shower window smaller and only up high.
Thanks everyone.
Leighton
432Meyers is offline   Reply With Quote
Unread 03-22-2019, 05:41 PM   #2
I'd use some 1x on the walls to bring it out a little, then wrap the framing of the window with whatever wall board you're using. What you want in the end is for the Kerdi to be about 1/4" or so over the window jamb, which would be sealed with silicone or other sealant.
Kerdi won't adhere properly to wood, so everything has to be covered with some type of tile backer.
For what it's worth, sheetrock is a suitable backer for Kerdi, and it's what Schluter recommends. It's much easier to work with, and less expensive. However, if you prefer to use a cement board, that will work as well. It's good to know ahead of time that installing Kerdi over cement board is much more difficult, especially for a newbie, since CBU draws moisture out of the mortar very quickly.
Unread 03-22-2019, 06:30 PM   #3
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I'd approach it in a different way. Remove the old window frame and install a fixed window, creating a sill on the interior which will act as a niche as well. Movable sash on shower window is a yuck collector, although bulk water should find it's way out via the weep holes built into vinyl frame.
Old window frame would not be my preferred starting place. Most are not tied to the house frame all that well.
Actually, I'd make my own frame and have tile and waterproofing running up to glass, but it's more work and possibly a little daunting for one new to the game.
Kerdi board makes for a good window surround.
Peter
Unread 03-22-2019, 07:14 PM   #4
432Meyers
Thanks Kevin and Peter.
Kevin - are you saying Kerdi needs a minimum wrap of 1/4" into the jambs or is that as far as you usually wrap it? I was going to wrap it all the way to the vinyl frame and adhere it there.
note taken about the drywall in place of cbu. like others, I'm not sure if I'm entirely comfortable with drywall and read that Durock isn't as thirsty as Hardie.
Peter- this window is one of those that wasn't tied to the frame well, it seemed to be floating. I added some framing on the sides and adhered the wood jamb to this framing and added some sill supports. Perhaps I can find another spot for this replacement window and look into changing strategies completely like you suggest.
Kerdi board as a window surround - do you mean in the jambs butting up to the window? or lining the jambs before window installation?
Leighton
Unread 03-22-2019, 07:42 PM   #5
rmckee84
rmckee84's Avatar
Here's how I usually treat windows. Also put kerdifix where kboard meets window.
Sent from my VS987 using Tapatalk
Ryan McKee
Unread 03-22-2019, 07:52 PM   #6
432Meyers
Thanks Ryan, that's mostly what I had in mind, minus the Kerdiboard.
I'm going with 3x6" subway tile which I guess is relatively cheap so I'll have to take another look at using Kerdi board in place of cbu. seems pretty slick
Leighton
Unread 03-22-2019, 07:58 PM   #7
432Meyers
On a separate note, the bathroom tub doesn't span the entire width of the room. I thought that I could use this to incorporate a nook out of the side wall by the shower head while still providing a continuous floor to wall surface for a shower curtain.
Will this present any difficulties that I, as a newbie, can't even imagine?
Leighton
Unread 03-23-2019, 05:03 PM   #8
rmckee84
rmckee84's Avatar
Should be ok, I dont see any real issues.
Ryan McKee
Unread 03-25-2019, 06:53 AM   #9
432Meyers
Thanks Ryan.
Another question:
I can get rid of a small strip of tile in my layout by tiling about 1 1/2" shy of a full 3' of cbu width. Will 1 1/2" of cbu and then the cbu to greenboard transistion be difficult to finish and paint over?
Leighton
Unread 03-25-2019, 09:01 AM   #10
In a dry area you can finish that joint and CBU the same as a drywall joint and it should be equally invisible.
Unread 03-25-2019, 09:17 AM   #11
432Meyers
Great. It's 6 in. outside of the curtained shower, so I'll plan on that.
Leighton
Unread 03-27-2019, 06:59 AM   #12
432Meyers
Is there any advantage to designing the shower surround wall one way or the other?
The tile would either be set parallel or perpendicular to the tub - any difference?
And in terms of waterproofing and possible water run off to the floor from the tub?
Any thoughts? Thanks again.
Leighton
Unread 03-27-2019, 07:03 AM   #13
432Meyers
Also, decided to use Kerdi board, would have liked to try the Durock system, but it's a bit of a drive to pick up those components.
Leighton
Unread 03-27-2019, 07:25 AM   #14
The Durock Shower System components are available from Amazon, Leighton.
Unread 03-27-2019, 07:53 AM   #15
Carbidetooth
Hmmmmm
Concerning design and intersection of elements.
I find it's almost always better, both looks-wise and execution-wise, to offset surfaces rather than trying to keep them in plane. There are exceptions, of course, but it's something to bear in mind.
Houses and components of houses are not truly square, flat, coplanar, level or otherwise perfect. This coming from someone who wants them to be, 'cuz his first jobs were in cabinet shops...
Peter
Rotted tiled window sill and wooden window in shower Sean12 Tile Forum/Advice Board 6 01-15-2019 10:44 AM
Shower Window niche framing n waterproofing HappyPam Tile Forum/Advice Board 6 09-20-2018 01:01 PM
Shower window - tile to window frame transition suggestions Fahrns Tile Forum/Advice Board 4 03-06-2012 01:21 PM
Window Framing Question? jerseyreef The Mud Box 16 09-20-2007 09:24 PM
help! shower screen not flush with tile barajama Tile Forum/Advice Board 4 11-06-2004 07:56 AM
