Unread 05-24-2019, 04:39 PM   #61
GHR
I straightened the edge with a break away razor. It's mostly ok now, but as I had hoped not to do I have unequal front edge overlap on the outside corner to the wall. 1" down to 9/16". The correct thing was to scribe the board to the wall. But what has happened is why I did not want to.
I'm starting to feel like this is the unlevel table issue.
Take an inch off each table leg its still unlevel. Keep going eventually it's only 1 foot high.
I'm Henry
Money talks alright... All ever says to me is "Goodbye!"
GHR is offline   Reply With Quote
Unread 07-26-2019, 12:05 PM   #62
GHR
Question
I'm looking to work more on this project. Got the plumbing done; moved the shutoff valves down below the vanity, but the plumber had to notch out a stud to make room to get a couple of fingers in to access it. The reason being the cold water line to the toilet crosses behind the hot at 90 degrees and leaves no room to work. And no room to anchor wallboard to make a tidy access panel. I jury rigged a sheetrock panel with hopes not to need to shut off any time soon.
Back to the countertop;
I got the kerdiboard edges trimmed to match the wall issues. I also now have only 1/4" of kerdiboard overlapping the vanity edge due to the trimming. But I can live with it since I have to. (Can I glue kediboard edge to edge with kerdifix at all? I have intact cut pieces.)
I still have a bow in the front edge of the vanity or warped Kerdiboard.
After a couple of go arounds with shims I tried something low tech.
I put a 50 pound sack of versabond on top. The gap disappears on
all sides.
So my question now is about shear strength of kerdifix and the kerdi on the kerdiboard. If I put kerdifix on the edges of the vanity, position the board as I want it, and put the weight on top will the kerdifix hold?
OR will the shearing force of the bow eventually break the kerdiboard loose?
Remembering too I still must cut a hole for the sink cutout which could jar something loose.
I'm Henry
Unread 07-29-2019, 11:34 AM   #63
GHR
Bump @ last post above....
I'm Henry
Unread 08-05-2019, 05:17 PM   #64
GHR
update
I got it figured out how to fix the gap. After months of trying shims
that were not going to work.
I found short screws and put a piece of composite wood (same type I was told to use as a ledger board in the shower) on the inside of the front edge of the cabinet. I kept thinking they would poke through the laminate ruing it.
1.5" screws did the trick though.
I was able to use the level as a guide and it seems to be working OK with kerdiboard on top. It's now flush with the top of the vanity edges on rear, left & right sides and with this piece of wood in front albeit the ends still have some gap. I cannot fix the gaps since they are over the two drawers.
It's more than enough to make sure once fixed in place it's not going to move or come loose -ever- without wrecking the kerdiboard.
I have a tiny bit of unlevel toward the wall too.
But it's not an issue unless someone tells me otherwise.
I'm Henry
Unread 08-14-2019, 01:59 PM   #65
GHR
How to open new tube of kerdi-fix?
This might sound like a stupid and moronic question but how do I open the tube of kerdifix?
It's not the usual pierce with a sharp pin it's more like it needs to be cut off using a razor? Any tips?
I don't want to have it gush out of the tube which seems like it could
happen if I cut it with a razor.
Photo attached.
I'm Henry
Unread 08-14-2019, 02:11 PM   #66
Elkski
Elkski's Avatar
Yes you must cut off 1/16" cut onto a board away from yourself. Use gloves. Sticky stuff. Cleans up with acetone or alcohol.
Teddy
Unread 08-14-2019, 02:25 PM   #67
GHR
Thanks.
All I have are breakaway razors. I hope it will have enough stiffness to cut it off and not break. Wish I'd've noticed this on one of my many trips to home depot over last two weeks.
I'm Henry
Unread 08-14-2019, 06:34 PM   #68
PC7060
PC7060's Avatar
Breakaway will work fine. Not under pressure so don’t worry about gushing out.
Unread 08-14-2019, 09:07 PM   #69
What your fingers don't cut yourself
Unread 08-14-2019, 09:31 PM   #70
If you're careful you can use a 1/8" bit and drill through the top.
Unread 08-14-2019, 09:37 PM   #71
But then you'd have only a 1/8th" hole, Kevin. Waaaay to easy to just slice off the top with a utility knife.
Unread 08-14-2019, 09:44 PM   #72
GHR
Smile
Thanks everyone.
I managed to get it cut and didn't break the breakaway blade.
I got my neighbor to use his rock-steady hand to xacto blade the sink
template. Now I just need to cut out the sink hole. I was waiting for
the kerdifix to dry fully to be sure it's not gonna jiggle loose while
cutting out the hole. I marked the hole position.
The only thing that can go wrong now is screwing up the cut for the
self rimming sink. I've done this before but never in kediboard.
I'm Henry
Unread 08-14-2019, 10:38 PM   #73
FWIW, in class, they told us that KerdiFix cures at about 1/8"/day from each edge towards the middle. So, depending on how it's applied, it could take awhile to gain full strength. But, the cured stuff is very strong. ON a 2" thick piece, triangular shape, Kerdifixed into a corner to Kerdiboard from around 4pm to 9am, I was able to stand on it and it held my 220# or so. Considering that only about barely 1/8th inch out of the 2" thick thin layer had cured in that timeframe, I was impressed.
Unread 08-15-2019, 08:12 AM   #74
GHR
Post
Yeah the bond strength is impressive. I've seen the Schluter videos of putting 3 men on a shower seat made of kerdi board with no bottom support. I cannot remember if that was kerdifix onto the wall or not. I only used a tiny bead (the new kerdi fix has a pre sized hole in the tip which I presume IS 1/8" or less) except on the four corners where I glopped it more.
BTW, how air tight is the tip with that screw-on cap? Do I need to put it into a zip lock? I don't want it to dry out before I get to the master bath countertop in a week or so. (might be too late )
I'm Henry
Unread 08-15-2019, 10:45 AM   #75
GHR
I got the sink hole cut *finally*. I'm terrible at making such cuts. Almost ended up with an oval shape instead of round (I must have twisted the jigsaw while cutting even though I thought it was flat) so I'm glad this is a top mount self rimming sink. I may need to be creative tiling that area.
I have another bathroom to do after this one with kerdiboard so I will have to make sure I am more careful in making *that* cut.
Now, onto tiling once I get time.
I'm Henry
Replacing bathroom vanity with tile floor and backsplash trenolds39 Tile Forum/Advice Board 3 02-10-2018 06:14 PM
Bathroom Vanity Backsplash Install ? jmckeone Tile Forum/Advice Board 2 09-19-2013 01:47 PM
Bathroom Vanity Backsplash cbaur88 Tile Forum/Advice Board 16 10-20-2010 01:31 PM
Need help with vanity backsplash BillMelvin Tile Forum/Advice Board 25 11-06-2007 10:00 PM
Huge Gap in Vanity Top Backsplash shorty Tile Forum/Advice Board 9 01-28-2006 06:59 PM
