Unread 06-05-2016, 03:46 PM   #1
topaz1975
Problems with "professional" stacked stone veneer install on brick fireplace
So i was too lazy to do it myself, and got a professional to install stacked stone veneer on our old brick fireplace. They just left after 3 days and are 90% done and I am not so crazy about some of the results.
I have never worked with this type of stacked stone myself, so I am not sure what kind of gaps and tolerances are normal, but some seem to me that they are not acceptable.
Also, there are over a dozen spots where the corner of the stone has splintered off when they cut it. Again, is that acceptable with this type of material, or not?
Just curious what others have in experiences with these stone veneers. We used actual real stone (quarzite) that comes in 6inx24in panels, similar to this:
(thats homedpot, it wont let me post the link)
MS-International-Golden-Honey-Ledger-Panel-6-in-x-24-in-Natural-Quartzite-Wall-Tile-LPNLQGLDHON624/205906536
Im posting some pictures of the gaps and splintered pieces. Also on one side the edge/ transition to drywall seems very unfinished to me, and also has an inch wide gap.
Gene
topaz1975 is offline   Reply With Quote
Unread 06-05-2016, 05:43 PM   #2
sycamorebob
That does not look good... May-be some pictures not so close up?
Link: http://www.homedepot.com/p/MS-Intern...N624/205906536
Patrick
sycamorebob is offline   Reply With Quote
Unread 06-05-2016, 05:47 PM   #3
Welcome to the forum, Gene.
No you didn't.
What you have there looks pretty bad. As requested, more pics.from further back.
Unread 06-05-2016, 05:58 PM   #4
Welcome, Gene.
How 'bout you back up a little and give us a photo with some perspective of the installation.
I've never had a problem cutting those stones without chipping. What tool were they using?
Unread 06-05-2016, 06:30 PM   #5
rmckee84
rmckee84's Avatar
Looks like a hack job...
Ryan McKee
Unread 06-05-2016, 07:26 PM   #6
I hate to pile on but that looks bad. It should be obvious to the installer that if the stones are butted together within the panel then the panels must also be butted together. There's no other way that it will look right, they must be butted. A no brainer to most folks.
Unread 06-05-2016, 07:27 PM   #7
topaz1975
as requested, a few more pics from further back. It's not completely horrible, from 10 feet away it looks ok. But for just "OK" I could have done it myself, this was a $5500 job including material and a small 10ft section of walkway that they repaved.
They cut the stone veneer with an angle grinder, not sure if it even had a diamond blade. The other thing that I questioned: They went right over the brick with no scratch coat or backerboard, which wasn't easy. There were about half a dozen granite pieces in the brickwork that they had to chisel off first (took one guy a full day on those).
Also, one of those two shelves is totally not level, it is an inch too low on the left side. And the transition between the stone and wainscoting is a total joke. Just noticed that one...
Gene
Unread 06-05-2016, 07:32 PM   #8
There's a reason it's called dry stack. I don't think you're being unreasonable to demand that they fix it. I hope you haven't paid them yet.
Unread 06-05-2016, 08:02 PM   #9
topaz1975
Thank you all for your replies.
I am wondering what they could do to fix it. Can you grout the worst gaps, or would that make it look even worse? Other than that they would have to take out all the damaged or ill fitting pieces and fit new ones properly?
Gene
Unread 06-05-2016, 08:55 PM   #10
I don't think I'd try to grout anything.
I think I'd take a few minutes and look over the entire installation and pick out the places that bother me the most. Put a piece of blue masking tape on each spot to mark it. Point them out to the installer and tell him you'd like those pieces removed and replaced with better fitting pieces.
If, by chance, there are so many that you can't live with, a complete redo might be in order, but it doesn't seem to be as bad as that. The best thing you can do is have an honest conversation with the installer on a professional level.
Unread 06-06-2016, 12:59 PM   #11
I don't think the lack of CBU, and the lack of a burn coat, is an issue but the wide gaps and un level shelf certainly are IMO. There's no way I could live with that - it would eat at me every day, regardless of price paid.
Unread 06-06-2016, 06:55 PM   #12
topaz1975
Thanks again for all your feedback. I followed Kman' advice and marked the worst spots with tape and sent them a list of what I didnt like. In my lunch break i came home and we went over the list. They were not happy at all, but ultimately spent an extra half day fixing 80% of what I listed, and the rest are minor things that we can live with.
Gene
Unread 06-06-2016, 10:23 PM   #13
dhagin
Good for you.
dana
Unread 06-07-2016, 05:36 AM   #14
Glad it worked out.
veneer stone over painted brick fireplace diddly Tile Forum/Advice Board 8 06-28-2014 03:23 PM
stacked stone veneer joeperi Tile Forum/Advice Board 1 07-23-2013 04:26 PM
1x2" stacked stone fireplace corners: to mitre or not to mitre JoeC Professionals' Hangout 12 02-22-2013 04:35 PM
Stacked Stone Veneer on drywall? Brekdwn5 Tile Forum/Advice Board 14 06-21-2010 07:52 PM
"Stacked Brick" - Product Recommendation Please jimG Tile Forum/Advice Board 5 09-20-2006 06:09 PM
