Unread 12-23-2004, 10:37 AM   #1
axroh
kitchen backsplash design advice (pics!)
Hi all,
I've used this board so much now and can't thank all you guys enough. So far, I've tiled 2 bathroom floors and a shower enclosure and a kitchen backsplash. They're not perfect, but gosh I love 'em
Anyway, here are some pics of my backsplash. (how do you like my design behind the cooktop? ). At the time though, the wife thought it best to leave this tile as a 6" backsplash, but I've convinced her otherwise - I want to take the tile all the way to the cabinets. My question is more of design:
1. should I continue the same vanilla pattern ?
2. should I put them on diagonal? with some molding in b/w? Won't that take the attention away from my diagonal pattern behind the cooktop?
The tile is a Walker-Zanger travert. 6". The backsplash behind the cooktop is the same, and the patterned tiles are actually engraved (mucho $$$ for that center one - I thnk I paid $33 for that one).
Advice appreciated. Oh, and the name is "Amit".
- AR
axroh is offline   Reply With Quote
Unread 12-23-2004, 11:22 AM   #2
Marge
Marge's Avatar
Hi Amit,
It's definitely a personal preference kind of thing.
If you lay the remaining backsplash using the same pattern it will definitely blend in and not stand out.
Diagonal for the remaining tiles would definitely draw your eye to the area and may be more than you seem to want.
Have you thought about making the middle diagonal and top square like the bottom? That would lead your eye to the diagonal of the cooktop. Just my opinion.
You will love having counter to cabinet backsplash..it changes the whole feel of the space. Also, your current work looks really great! Let us know what you decide to do.
Marge
Unread 12-23-2004, 11:58 AM   #3
KGW
Personally I feel like because the motif behind the range is the same height as your backsplash, you don't want to do anything to take away from it. I would probably lay the rest of the tile on the orthogonal instead of on the diagonal. I think that mixing it up in such a narrow space with such large tiles would detract. If you think a grid is too plain, consider setting the tiles in a running bond. In either case, I think a pattern 3 full tiles high would look way nicer than how cut up it would be to lay those tiles on the diagonal. You have a nice centered pattern above the range but I think it would look pretty haphazard trying to do the rest of your backsplash in diagonal at this point.
KGW is offline   Reply With Quote
Unread 12-23-2004, 02:24 PM   #4
axroh
what's a "running bond?" Does that mean staggered?
- AR
Unread 12-23-2004, 02:48 PM   #5
yep...
Unread 12-23-2004, 06:30 PM   #6
axroh
Thanks all for your replies. I'll maybe stagger them or just line'em up.
- AR
