Unread 11-26-2012, 02:14 PM   #1
bobbby2679
Floor level/transition nightmare
I am remodeling two bathrooms in the same house at the same time and we got through the first one successfully but have run into a problem on the second with the floor. I have a tile pro here now to install the tile and he just pointed out to me that the floor that someone else installed will be lower than the other rooms that connect to the bathroom. (there are 2 separate doors going in to the bathroom from different rooms) At one door it will be about 1/2" lower with the tile installed and at the other door it will be about 7/8" lower with the tile. The subfloor and durock are already installed. (1st lesson learned, next time I will have the guy doing the tile install the subfloor, too!) The tile guy says the best solution he can think of is to use either floor leveler or something called Jipcrete (sp?) to level out the entire bathroom floor. It would either be that or else we would have to rip out all of the durock and subfloor and somehow re-shim under the subflooring to get a floor that is both level and at the correct height to transition into the other rooms. Just wondering what you would do in this situation?
Bobby
bobbby2679 is offline   Reply With Quote
Unread 11-26-2012, 02:54 PM   #2
Rip out all of the durock and subfloor, sister the joists to the right level, then reinstall the subfloor and install new durock.
Unread 11-26-2012, 06:17 PM   #3
bobbby2679
Yep, that's what we are going to do. Once I figured out just how many 50 lb bags of leveler we would need for the bathroom (about 12 bags!) at $30 each, just pulling up the whole damn floor didn't seem like such a bad idea after all! Thanks!
Bobby
Bathroom floor nightmare Arek Tile Forum/Advice Board 4 10-05-2006 01:59 PM
Shower floor nightmare? few3 Tile Forum/Advice Board 4 03-13-2006 01:06 AM
Nightmare on the 2nd floor relling Tile Forum/Advice Board 1 02-20-2006 12:11 PM
Marble floor nightmare pageintl Tile Forum/Advice Board 3 05-22-2002 05:41 PM
to level or not to level bath floor jmc Tile Forum/Advice Board 12 05-19-2002 09:22 AM
