Unread 11-26-2012, 10:07 AM   #1
NCG
Tile Floor On Covered Deck?
I have an enclosed, second story, covered porch that will soon be ducted for heating an air conditioning. When it was still an outdoor deck, before the roof was constructed, and walls/windows installed, I replaced the 2 x 6 floor with Trex boards laid (screwed over 2 x 8 joists. There is no plywood subfloor. The bottom of the enclosed deck is insulated, which is covered with plastic siding material. So what was once an uncovered outdoor deck, will be another room in the house.
I'm now thinking of installing a tile floor over the Trex boards, (maybe even some sort of laminate (??). My question is what kind of underlayment would be a good choice for such an application. Can the subfloor be laid over the Trex, or should the Trex be removed first?
Thanks for your advice.
Nick
NCG is offline   Reply With Quote
Unread 11-26-2012, 10:17 AM   #2
The Trex should be removed first. It's 50% PVC or something. You want plywood, then some sort of tile underlayment, either backerboard or a membrane.
The above presupposes the deck was constructed on par with a normal floor and the joists meet L/360 deflection criteria. Many decks do not meet either supposition.
Tiling a Covered Deck lothian Tile Forum/Advice Board 14 11-03-2011 09:44 PM
Exterior deck, vinyl covered- what underlay? belletile Professionals' Hangout 1 03-24-2008 08:41 PM
Installing slate on cement floor covered with carpet glue Bwinn Tile Forum/Advice Board 1 01-14-2008 06:02 PM
Covered Porch floor drain Bon Tile Forum/Advice Board 3 07-11-2006 10:00 AM
covered outdoor deck is getting tile dbol Professionals' Hangout 13 07-05-2006 06:38 PM
