First off I used this forum to complete my kerdi shower project and its been in for a few years now with no issues thanks to this forum
Now I'm starting our kitchen backsplash project so I have a few concerns as well as products to use. Our kitchen counters as well as backsplash was all ceramic 6x6 tiles. We finally had granite installed and will be installing 3x6 tumbled travertine in a subway pattern with 1/2"x1/2" glass inlay going along middle of backsplash the length of wall.
First off I will tell you my concerns. When they demoed the wall tiles some drywall was damaged. I have replaced the areas that were big but some of the smaller areas I'm wondering do I just re-mud the damaged spots? I have chipped away at the excess thinset and got most of it off. I did notice that some of the original drywall had oil based paint on it and they scored it to get a bond but it came off really easy compared to the raw drywall. Do I just sand with 80 grit or use a primer insted to get a better bond?
After I have walls relatively clean of excess thinset and all damaged drywall re-muded, can you float a thin layer of thinset to get a fresh bonding surface or is that not needed?
Aslo thinking about adding a section of kerdi band behind sink area just for water barrier.
Now onto products to use.
1. What thinset is the best for 3x6 tumbled travertine with the glass inlay I am installing?
2. what size notched trowel?
3. Do I use a grout release or seal the tile (511) prior to grouting because tile is porus with voids and don't want to fill voids with grout?
4. Do I use caulk style grout where tile meets countertop?
5. Smallest grout line I can go? sanded or non sanded grout?
If I've missed anything fell free to add any suggestions.
Thanks again...
Dano
