Unread 11-25-2012, 08:25 PM   #1
Shanehaz
Kerdi/flextile wp-980
Ok so i've started my first shower and i'm a little concerned. Too much conflicting information from different people. I've installed kerdi on the floor and the bottom 30" or so. Then I installed flextile wp-980 over the top half of the shower (over denshield). I also painted the corners of the kerdi with the flextile liquid, which I probably shouldn't have. (I did use the kerdi corners and band as well) Kerdi calls for un-modified thinset while flextile calls for modified. Should I just use a lightly modified for the whole thing? Tiles are 1" x 2" porcelain on floor and 10" x 13" on the walls. I'm not concerned with warranty I just want the tiles to stick and it not to leak.
Shane
Shanehaz is offline   Reply With Quote
Unread 11-25-2012, 08:29 PM   #2
Executive Flooring
Executive Flooring's Avatar
Using something lightly modified (like Versabond) should work fine
Ray
MA/NH Home Remodeling
Executive Flooring is offline   Reply With Quote
Unread 11-25-2012, 08:38 PM   #3
Shanehaz
Shane
Unread 11-25-2012, 09:07 PM   #4
Hi Shane, welcome to the forum. Wow, that's.....uh....colorful.
I see you have Denssheild on the upper half. What about the lower that's covered by Kerdi, what is the substrate there? What thinset did you use to install the Kerdi, KerdiBand, and corners?
Unread 11-25-2012, 09:15 PM   #5
Shanehaz
Denshield lower half as well. Hardibacker over 2x4's for the curb. Kerdi was applied with premium plus non modified thinset.
Shane
Unread 11-25-2012, 09:17 PM   #6
Shanehaz
You should've seen how colorful it was before the flextile dried. Orange and purple. Lol
Shane
Unread 11-26-2012, 12:20 AM   #7
Shanehaz
From flextile....Ceramic tile or stone must be installed using one of the following Flextile Latex Portland Cement Mortar systems (ANSI A118.4-1992): Flextile #52 Versatile, #51 or #53 Thin-Set Mortar mixed full strength with #43 Acrylic Mortar Additive or #44 High Solids Acrylic Mortar Additive
Shane
Unread 11-26-2012, 05:37 AM   #8
bbcamp
If you use that mortar system on the Kerdi sections to set your 10x13 inch tiles, expect a very long drying process.
I'm curious about the corners. Does the Kerdi overlap? If not, did you use reinforcing fabric in the liquid waterproofer?
I'm even more curious about why you chose this hyprid combination.
Unread 11-26-2012, 03:03 PM   #9
Shanehaz
yes the kerdi overlaps on the bottom with the Kerdi band and kerdi corners under ther Kerdi. The top has the reinforcing fabric in the liquid.
I had someone give me the liquid and wasn't fully confident using it. After doing some research I decided on going with the Kerdi system. I was just going to do it on the bottom half and figured the denshield woulkd be fine for the top. Since I had the liquid I was told why not put that on the top half of the walls. Why I painted the seams on the bottom half....I'm not sure, I was a little concerned that maybe I pressed too much thinset out as some of the edges wern't the most solid (maybe 1/4" lifting in a few spots). I'm sure it would have been fine as I had the 2" overlap. Maybe if I didn't paint the corners and edges I could use modified on the top and un-modifed on the bottom, or maybe I can still do that??? or should I just use versabond? Thanks for the advise!!
Shane
Unread 11-26-2012, 03:07 PM   #10
bbcamp
How long can you wait for modified thinset to dry under your tiles?
Unread 11-26-2012, 03:21 PM   #11
Shanehaz
well, my wife will wait as long as she has to wait.....LOL
I'm in no rush
Shane
Unread 12-01-2012, 12:48 PM   #12
Shanehaz
Here's what I'm debating between;
1. Use unmodified for the bottom half and modified for the top half. It's only about 2" in the corners of the liquid waterproofed. Hopefully that'll be fine.
2. Use modified for the whole thing and wait like a month before I grout.
I've heard of people doing 2 before but never 1. So am I best with the modified??
Thanks for the input
Shane
Anyone used Flextile, Tec or Chembond mortars? Which do you like best? mcvg2002 Tile Forum/Advice Board 20 12-27-2011 11:02 AM
Anybody tried Flextile acrylic grout? Lakeside tile guy Professionals' Hangout 6 12-06-2010 07:35 PM
Pro-Va Shower System + Flextile 200 Multi Adam Peckham Tile Forum/Advice Board 3 05-17-2010 05:55 PM
Flextile 52 Modified Thinset: Just Add Water? RedEarth Tile Forum/Advice Board 5 01-20-2006 04:08 AM
Flextile 200 Adhesive or Versabond? ehrets Tile Forum/Advice Board 7 06-04-2003 12:33 PM
