Old 06-06-2019, 07:41 PM   #1
lati_cz
michal
electric question
I have garden shed with 50amp sub panel in it. There's few outlets and a light in the shed. Outlets are rarely used to charge battery tools.
I am planning to put hot tub close to shed. I need 50amp breaker for hot tub, can I hook up the tub on sub panel I have? Main panel is far and new wiring will require lots of digging....
thank you. Michal
Michal
lati_cz is offline   Reply With Quote
Old 06-06-2019, 09:23 PM   #2
The first thing I would do is verify the size of the cable supplying the sub panel. It wouldn't be unheard of to use a 30 amp cable with a panel that's rated higher.
It should be a #6 cable to run a 50 amp, so if that's the case you could run the tub, but theoretically that would be all. Normally a person would run more than needed, which in your case would be better if it was a #2 or 100 amp cable.
Considering the downside, which could be an electrical fire, I would run a separate cable for it. Those tub heaters can pull some amps in the winter time.
Maybe you'll get lucky and the cable was oversized.
Electric radiant floor heat question sparky123 Tile Forum/Advice Board 4 02-06-2014 06:26 PM
Subfloor and Electric heat cable question kentnrobin Tile Forum/Advice Board 4 12-30-2011 07:57 PM
Question about in-floor electric heat and appropriate substrates chriswand Tile Forum/Advice Board 2 03-14-2010 05:30 PM
electric radiant heat $ question Mr T Professionals' Hangout 12 12-22-2006 04:20 PM
220 electric heat under tiles - question lowella Tile Forum/Advice Board 48 05-01-2002 09:08 PM
