Unread 01-17-2008, 11:33 PM   #1
JarekS
Storing travertine in a garage, cold temps?
Did a search but didn't find anything. Can I store travertine in their original boxes, in the garage with temps hitting -10 C/14 F?
Thanks.
Jarek
JarekS is offline   Reply With Quote
Unread 01-18-2008, 12:29 AM   #2
muskymike
muskymike's Avatar
Sure.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 01-18-2008, 12:34 AM   #3
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Hi Jarek,
Sure, you can store it safely at cold temperatures but you'll want to take a few precautions regardless of the cold. Stone should be stored standing up, on it's edge, to prevent the weight of stacked stone from crushing/cracking the stones on the bottom. You should probably also store it off of a garage floor to prevent moisture from being trapped under the tile for long periods of time, which might cause staining. Two parallel 2-by-4's laid on the ground provides enough air circulation and takes up very little space.
I also like to bring my tile in out of the cold a bit before I plan to set them to warm them up to the room a bit. While this may not have any scientific benefit, it does make handling the tiles a little more comfortable which in turn means a surer grip and less potential for accidents.
Best of luck,
Shaughnn
Unread 01-18-2008, 12:37 AM   #4
Brian in San Diego
Brian in San Diego's Avatar
Jarek,
Please don't start new threads for every question you have. I know it may not seem related, but it's still part of the travertine floor project you have started a thread on.
And to elaborate on Mike's answer...it's a rock! Don't you think it might have seen temperature extremes in it's life before becoming a tile in a box in your garage?
Unread 01-18-2008, 07:54 AM   #5
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Brian,
The rule is that we don't like to see multiple threads on the same topic, but multiple threads by the same member are still allowed. In this case, a separate thread is fine because it's not at all related to the installation.
I've seen stone tile ruined by storing it improperly. Some cardboard has a high acid content (white paper) and a damp storage area can etch the edges even though the tiles are facing inward. I've also seen cardboard disintegrate and become an indelible stain through the stone. Even though it's a "rock" it's still a good idea to protect your investment by treating the material with care.
Shaughnn
Unread 01-18-2008, 08:59 AM   #6
Brian in San Diego
Sorry Shaughnn, my attempt at humor. Jarek asked about temperature and that's what I keyed on.
