Unread 12-22-2005, 09:09 AM   #1
chrisb5180
Cement Backer Board
I have just finished putting up cement backer board in my entire shower area. Can I now start to tile the area or should I apply something to the backer board first,
chrisb5180 is offline   Reply With Quote
Unread 12-22-2005, 09:18 AM   #2
chassis
Chris,
What is behind your backerboard? You need a vapor barrier somewhere in the wall construction. If you have builder's felt or plastic sheeting behind the cement board, all you need to do is tape/thinset the cement board joints and you're ready to start tiling. If you don't have a vapor barrier behind the cement board, you need to add one in the form of a membrane such as RedGuard, manufactured by Custom and available at Home Depot. Tile can go on the wall after ther RedGuard is dry.
You'll probably need to tape and thinset the cement board joints before RedGuard.
Will
central Indiana
chassis is offline   Reply With Quote
Unread 12-22-2005, 09:56 AM   #3
pgabriel
Redgaurd...
Will,
Red gaurd isn't available up here in the NorthEast. The giant orange cube store gave me the "that product doesn't exist" look. Then they offered what is called "DryLok" which is a masonry "waterproofer" but it's main use is to paint on basement walls to prevent water from getting in.
I am wondering if this is the same thing, and can I use it with confidence.
-Peter
"A day in the corps is like a day on the farm. Every meal a banquet, every paycheck a fortune, every gathering a parade. I LOVE the corps!"
pgabriel is offline   Reply With Quote
Unread 12-22-2005, 10:11 AM   #4
Rd Tile
Tile Man
Rd Tile's Avatar
HD has it, it's in the tile isle.
DO NOT use Drylock for tiling.
Unread 12-22-2005, 04:43 PM   #5
Andrew21
Originally Posted by pgabriel
Will,
WHAT!?!?!? Don't ask anyone for the product in the 'orange cube store'. Just go in the tile area and look for the Redguard. You can't miss it. Its about $38.00 for the bucket.
Andy
Andrew21 is offline   Reply With Quote
Unread 01-05-2006, 10:19 AM   #6
chrisb5180
Tiling a Shower/Tub Area
I just finished putting up cement backer board in my shower area. What is left to do before I can start tiling?
Unread 01-05-2006, 10:32 AM   #7
What have you done so far (besides hanging the backerboard)?
It helps us if you keep all your questions about your project in one thread, even if you move from one phase to another. If you decide to tile a different area of the house, then start a new thread.
While you are here, go ahead and bookmark this thread so you can find it again. Add it to your Favorites.
Unread 01-05-2006, 10:36 AM   #8
chrisb5180
I have just put the backerboard up with no vapor barrier and I have not taped anything.
Unread 01-05-2006, 10:40 AM   #9
Ok, tape and mud the joints with alkalie-resistant backerboard tape and thinset, then coat the entire shower, excluding the floor, with Redgard, a waterproofing membrane by Custom Building Products (should be at HD).
Pay attention when you mud the joints. Feather out the thinset as much as you can to prevent speed bumps on your walls. It will make tiling much easier weth flat walls.
