Unread 07-11-2004, 01:20 PM   #1
dreamr
Alberta-Tile Guy
dreamr's Avatar
water proofing shower walls ?
Hi all , I just finished grouting (sanded) the shower walls with 12 x12 porcelain tiles with a 2" strip of 1" glass mosaic tiles around every 4" sq. block... what can I use to seal this wall ?
dreamr is offline   Reply With Quote
Unread 07-11-2004, 02:45 PM   #2
Davestone
Florida Tile & Stone Man
Well the best thing is to waterproof the wall under the tile. But now the main issue is the grout since porcelain and glass are impervious,and there are many good sealers with little rolling applicators or the corner of a sponge and caulk the corner joints with a wet area color caulk. Aqua seal or tyw impregnators.
http://Davestonestile.com
Unread 07-11-2004, 06:33 PM   #3
dreamr
Alberta-Tile Guy
dreamr's Avatar
Thanks Dave corners already caulked had an idea on sealer but just wanted to be sure... better safe than sorry THANKS!
You never stop learning!
Travis.
Dream Ridge Dev.Inc.
http://www.facebook.com/home.php?#!/...19876588024580
Unread 07-12-2004, 06:21 AM   #4
The big deal here is to NOT leave any sealer on the surface of the tiles. Let it "dwell" after you apply it, but only for a few minutes. Don't allow it to dry on the surface. Remove it with clean rags or paper towels. Polish it off until it gleams.
