Unread 06-26-2022, 06:12 PM   #1
Tripawd
Advice on tiling tub apron.
I have a tub that will need the apron tiled. Should/can the apron be framed so that the finished tile is flush to the front of the apron? Or does the framing on the apron need to extend out so there is a edge? If so, what can the minimal depth of the ledge along the apron be? Or can schluter edge be run along the the apron with no ledge?
Jayrod
Tripawd is offline   Reply With Quote
Unread 06-26-2022, 06:22 PM   #2
Welcome back, Jayrod.
Either way you want, ledge or no ledge, is fine.
Without a ledge, there's really no reason to use a Schluter profile there.
One thing you might consider is who will be climbing into the tub. Adding a ledge there will make it wider and a little more difficult to step over.
Tiling non-apron bathtub front MassDIY Tile Forum/Advice Board 8 04-28-2017 01:30 PM
Apron Air Tub Access Panel Advice 1sthome Tile Forum/Advice Board 0 04-06-2017 03:29 PM
building out the tub apron by furring it out and then tiling it? tc128 Tile Forum/Advice Board 2 03-08-2012 11:01 AM
Tub apron tiling? lbailey_1234 Tile Forum/Advice Board 4 03-27-2010 07:36 PM
Tiling a tub apron splatgirl Tile Forum/Advice Board 6 07-20-2005 06:43 AM
