Unread 06-15-2022, 03:36 PM   #1
njhusky
Best "Stain Proof" grout
Hi folks,
Tiling a ground floor den and needing to pick the best stain proof grout for the job...as my wife wanted a floating floor, since she is afraid of the grout getting dirty...but I convinced her to use tile.
I've seen Fusion Pro, Prism and Flexcolor CQ SpectraLock 1 mentioned in this thread....I have also seen TEC mentioned online.
Soooo...which do I use so I'm not proved to be incompetent....lol
Also...should I still seal it or is that not a good idea
Thx in advance
Mark
njhusky is offline   Reply With Quote
Unread 06-15-2022, 03:51 PM   #2
Welcome back, Mark.
Best to have your own project thread for such questions. Since you've already visited threads about sealing/not sealing, you're already about as informed as we can make you.
Some of the new "single component" grouts do resist staining quite well, and that allows spills to be cleaned up quite effectively. I've used them, but not on a floor application and can't say how well they hold up under the long-term abuse of residential foot traffic. I fully expect they'll get dirty just like cementitious grouts always have, but I can't prove that.
I think the best thing you can do is what my first tile guy taught me when I started building houses many years ago: Pick a grout color that closely matches the dirt outside the house.
As for sealing, that, again, is helpful in keeping some kinds of stains from "setting" before you can wipe them up if you're quick, but won't really help the long-term getting dirty that happens to floors.
Unread 06-15-2022, 05:26 PM   #3
Lazarus
Lazarus's Avatar
I like the Prism.....
Laz...
“Always listen to experts. They'll tell you what can't be done, and why. Then do it.”
Unread 06-15-2022, 05:28 PM   #4
Years ago I tiled a kitchen floor and sealed the grout. A few months later I went back to tile her backsplash and she sure was upset because the floor grout was showing dirt in the traffic areas. She told me the sealer I used didn't seal the grout very well. I had to tell her that all the sealer does is give you time to wipe up a spill and that she would still have to mop the floor. I guess she thought that the sealer made it so dirt wouldn't touch it.
In my opinion, the easiest grout to use is Prism and is my go to grout. But if you're worried about stains, Specktralock is what I'd use.
Unread 06-15-2022, 07:07 PM   #5
njhusky
I told my wife the grout color recommendation….she laughed heartily!! Luckily the grout will be a shade of gray….so this might actually be reasonably practical advice. Lol
Mark
Unread 06-16-2022, 05:20 AM   #6
RichVT
Vermont Remodeling Contractor
Similar to CX's advice, I was told that you should mop your existing floor. Whatever color the mop water is is the color you should choose for your grout because that's the color that it will end up being.
Rich
RichVT is offline   Reply With Quote
Unread 06-16-2022, 06:58 AM   #7
Tiger Mountain Tile Inc
I've used all of these with the exception of TEC and SL1 is the best but that's an opinion.
Keep in mind, Prism is a good grout but it's not in this category. It's a cementitious grout and could still benefit from a sealer.
James Upton
Unread 06-16-2022, 03:06 PM   #8
An epoxy-based grout or a one-part acrylic one is the least likely to stain, but none are 100%.
Which grout coloring sealer do you recommend? "Grout Renew","Grout Refresh", or ? Fun2Learn Cleaning, Restoration and Sealing 1 02-22-2016 07:25 AM
Water"proof" thin set remodel123 Professionals' Hangout 24 12-16-2010 02:13 AM
Using dry lock stain proof sealer on 1" hex porcelain debshome Tile Forum/Advice Board 1 01-12-2010 12:01 PM
Got the book! Now I've got proof for the "pros"! peteinsonj Tile Forum/Advice Board 4 08-13-2006 04:01 PM
Is there really a "stain-free grout" ? elka Tile Forum/Advice Board 6 09-14-2003 07:49 PM
