Unread 10-16-2020, 12:13 AM   #1
belinda_diy
Concrete box out drain/p-trap question
Hello All - this is my first post!
I have search the forum and found some similar posts but not quite the same. With the current environment, I have taken the opportunity to do some DIY and remodel the smallest shower. After I stripped the older neo angle shower pan, I noticed that there is a concrete box out with plumbing and p-trap which appears to be common in California. I have a schluter neo angle shower pan and will need to fill up the hole in order to have support. Is the best option to fill this hole with sand? Any help or guidance is much appreciated, thanks!
Bel
belinda_diy is offline   Reply With Quote
Unread 10-16-2020, 07:09 AM   #2
Hi Bel,
Looks like you've got room to re-locate the drain pipe before you fill the space. Use deck mud to refill it. Here's a short article:
https://www.johnbridge.com/how-to/deck-mud/
Unread 10-16-2020, 10:32 AM   #3
belinda_diy
Thanks John for the reply. The drain is in the exact place i need it, just need to trim off about two inches for the schluter drain to connect then the tray. If I re-located the drain, wont the same problem persist? I will still have the p-trap and drain in the hole i need to fill. Sorry if its a silly question was just hoping this would be easier, sigh...
Bel
No trap in shower drain aderi22 Tile Forum/Advice Board 3 11-02-2006 10:35 PM
shower drain/p-trap questions pogorat Tile Forum/Advice Board 2 08-02-2005 02:09 PM
OH No Shower Drain Trap Michael16 Tile Forum/Advice Board 2 03-01-2005 05:48 PM
HOWTO: shower over access hole around drain p-trap sunkid Tile Forum/Advice Board 85 09-28-2004 05:43 PM
My drain has no trap??? Possible? rob@netlumina.com Tile Forum/Advice Board 13 05-27-2004 11:16 PM
