Unread 10-13-2020, 04:57 AM   #1
aa7483
50 % running bond on on larger tile
Hello, I'm using some 4 x 12 (4.25 x 12.875) subway tiles for my bathroom. The manufacturer suggest going with 33% offset rather than 50% to minimize lippage. Is this tile really big enough to worry about that? I held the tiles face to face and there is almost no rocking.
I'd prefer to go with 50% since I like it better aesthetically and I'm having problems avoiding skinny tiles in the 33% variety. The house is 100 years old and already not perfect so I already have my hands full. I dont want to make matters worse but if I can get away with it I'd prefer it.
Thank you in advance
Anthony
aa7483 is offline   Reply With Quote
Unread 10-13-2020, 06:04 AM   #2
Hi Anthony,
Lay a small field of tiles 50/50 in the floor. If the lippage doesn't offend you, go for it.
Unread 10-13-2020, 07:36 AM   #3
aa7483
I did that and it looks totally fine to me. There is a slight rock in the tile when face to face but almost nothing. I think I'll go for it. Thank you.
Anthony
Unread 10-13-2020, 03:28 PM   #4
At 50%, that puts the highest point of the crowned tile next to the lowest point at the ends. It depends on the size of the grout joint how obvious any lippage will be and how well that can hide it. This is where a small sample board might settle your mind. Usually, it's best to go with the manufacturer's recommendations. Any offset works when the tile are perfectly flat, but that's rare. 30-33% offset hides it pretty much, as does stacking them.
Unread 10-13-2020, 04:58 PM   #5
aa7483
Yea im still messing around with it trying to make it work. Id like to do it to the manufacturers specs if possible. When they say 33% each row steps one third in from the previous row either toward the left or right depending on preference) creating a stair step look is that right? At first I was trying to alternate 1/3 2/3 and that just looked strange.
Anthony
Unread 10-13-2020, 06:15 PM   #6
Yes, like this. Every 4th row lines up.
Unread 10-13-2020, 08:00 PM   #7
aa7483
Yup, that's what I had in mind. I think i finally figured it out. It helped to trace the tiles out on the wall for visualization purposes. Got some smaller 3 inch tiles on the end but it is what it is. Mine is going to step in the other direction but I cant imagine that matters.
Any advice in drawing the layout lines on the wall? Ive already attached my board on the bottom for the vertical rows. Im assuming I should mark 3 lines with a level a 1/3 tile apart? How do I keep the lines visible. I figure ill lose sight of them once I thinset. Its been a while since I tiled. Trying to get all my ducks in a row
Anthony
Unread 10-14-2020, 05:49 PM   #8
The 3 inch cuts will only be in every 4th row. If everything is running plumb, the same 3 size cuts will repeat up the walls.
I figure out the size of the stagger from one row to the next. Say it's 4 inches. I set the bottom row and then set a tile above it, hooking my tape measure on a corner and making sure I off set it 4 inches from the row below it. Same thing with the next row. You can draw a plumb line so that the edge of the tiles on every 4th row are on the line and the other rows are evenly spaced.
Need advice with 12x24 Floor Tile in running bond layout. attdsltech Tile Forum/Advice Board 2 05-02-2020 03:40 PM
12x12 running bond Denver Chuck Tile Forum/Advice Board 26 09-09-2012 02:10 PM
versa bond calling tech for setting larger than 12x12's? rob 223 Professionals' Hangout 8 08-29-2004 04:04 PM
Layout of Running Bond Tile Robert Villa Professionals' Hangout 8 10-09-2002 07:08 AM
Layout Issues on Running Bond Subway Tile Robert Villa Professionals' Hangout 9 05-20-2002 11:33 PM
