Unread 10-09-2020, 10:46 AM   #1
SeaDog46
Plumber putty stain
Had new chrome fixtures installed on marble composite bathroom vanity. After install there were circular stains around new fixtures (see photo). I was told stains were from old plumbers putty. I'm new to this forum and am hoping to tap into your knowledge dealing with this problem. I did see some posts by jkmin from last year indicating Goof-Off and Mr. Clean and elbow grease helped him.
Have tried Stonetech/DuPont oil stain remover to no effect. Wouls appreciate any help the Pros on this forum could provide...Thanks
SeaDog46 is offline   Reply With Quote
Unread 10-09-2020, 05:19 PM   #2
Tile & Stone Guild
King Of Tile
Its cultured marble, more likely a chemical reaction. I would suggest a bigger escutcheon.
Jeff
Tile & Stone Guild is online now   Reply With Quote
Unread 10-10-2020, 03:51 AM   #3
Welcome to the forum, Mike.
Were the new fixtures installed by a pro? I ask because any experienced remodeler knows to use silicone instead of plumbers putty to set fixtures like that on cultured marble. They do make oil-less plumbers putty, but some installers also avoid that out of an abundance of caution.
I’ve not had any luck removing a stain like that. If the remedies you mentioned improve things, that means the stain is a surface contaminant, rather than a stain that’s gotten into the surface.
Unread 10-10-2020, 01:51 PM   #4
Hi Mike,
The surface of cultured "marble" is actually plastic. The plumbers putty might have destroyed the surface.
Unread 10-11-2020, 08:51 AM   #5
SeaDog46
Thanks John....Am trying several solvents as well as pastes. So far no luck so you may be correct.
Unread 10-11-2020, 08:58 AM   #6
SeaDog46
Hi Tool Guy.....Thanks for info. New fixtures were installed by pro who used a silicone based compound to set. He actually was the one who identified stain after removing old components.
Unread 10-11-2020, 09:02 AM   #7
SeaDog46
Hi Jeff....Thanks for reply. Given trouble so far removing stain I definitely will
look into going the larger escutcheon route.
remove stain on composite vanity top probably from plumber's putty jkmin Cleaning, Restoration and Sealing 15 06-12-2019 07:50 PM
Installed faucet on granite w/plumber's putty, is poultice necessary? BiggerJ Cleaning, Restoration and Sealing 2 08-07-2009 04:04 AM
Putty on slab opiethetileman Professionals' Hangout 3 10-21-2005 07:19 AM
Plumber's Putty & Granite Miller5717 Cleaning, Restoration and Sealing 3 06-04-2004 07:53 PM
Removing plumber's putty stain on granite tile? Rod A Wisconsin Tile Forum/Advice Board 2 11-13-2002 06:38 PM
