Unread 10-08-2020, 07:45 PM   #1
antamy
Kerdi curbless shower install questions
Just joined, so bear with me! I know there's another question similar to this from a couple of days ago, but didn't want to add to that.
I know how to install the Schluter TT tray. I have to trim mine down by about 6" for it to fit the odd space I have - as far as I can tell, that is permissible. A 48x48 will need to come down to about 41x42. If I'm wrong, please let me know! The shower entrance will have a narrow (15") wall next to it, so that's where the trimming will occur. From shower wall to bathroom floor will be the full 48", if that makes sense.
Secondly, I will use Kerdi board on the walls, so will seam everything with kerdi band. I want to be absolutely sure of the waterproofing so, a) should I use kerdi fix between the shower pan and the board, similar to how Wedi is installed? b) would I benefit from overcoating the kerdi band with hydroban or ardex? What about around the drain?
Would like to hear from someone who does this regularly, since my tile guy has never even heard of this stuff!
Anthony
antamy is offline   Reply With Quote
Unread 10-09-2020, 05:34 AM   #2
Hi Anthony,
I would use only Schluter products in the shower. The system has been in use for a very long time now. Kerdi band is the only thing you need at all the joints, including the juncture of the the walls and floor. A two-inch overlap is specified. The band is a little wider than necessary, so achieving the overlap is not a problem.
All of the basic installation info, including videos, is available on the Schluter website: www.schluter.com
Unread 10-09-2020, 08:23 AM   #3
antamy
Thanks for the response!
Anthony
Curbless install questions ericgu Tile Forum/Advice Board 3 05-26-2015 04:07 PM
Shower install: glass mosaic v. Kerdi system questions sporges Tile Forum/Advice Board 3 12-29-2008 01:21 AM
how to install curbless shower? rancher Tile Forum/Advice Board 3 03-07-2005 06:04 PM
Kerdi shower install questions peterd Tile Forum/Advice Board 15 04-28-2004 06:46 AM
curbless shower install ski Professionals' Hangout 10 12-12-2003 08:38 AM
