Unread 10-01-2020, 07:49 AM   #1
dbcriss
Shower doors for a curbless shower
This will be my first curbless shower. I'll recess a Schluter kit into the floor and there will be no curb or entrance ramp. I'm wondering about the shower door.
There are the semi-frameless bypass sliding doors, or another choice are the one fixed panel / one pivot panel doors. Is one better than the other at keeping water in the shower?
Is one style better than the other for rolling a chair in and out of the shower? (This is not intended to be an ADA compliant shower.)
Or there other ways to go about keeping the water within the shower?
Thanks, David
David
dbcriss is offline   Reply With Quote
Unread 10-01-2020, 08:00 AM   #2
e3
where is the drain located related to the door?
What size base? 1% or 2% slope ?
Do you plan on waterproofing the entire bathroom or extending the waterproofing beyond the shower threshold?
Eric
Noble Company
Unread 10-03-2020, 04:29 PM   #3
Hi David,
If you go for a swinging door you'll need a plastic sweep on the bottom of it to keep the water in. Also, you won't be able to have a mat right outside the door.
Unread 10-04-2020, 03:14 AM   #4
Some folks will build a very gentle and shallow “speed bump” at the location of the door to assist in: keeping the water in, maintaining 2” of drop between the height of the curb and the top of the drain (might be plumbing code by you), and helping with install of pivoting door with the plastic sweep on the bottom edge like John mentioned. ...something to consider.
Unread 10-04-2020, 09:18 AM   #5
Tiger Mountain Tile Inc
I prefer the hinged door with no pivot because they are going to want to screw the pivot through your waterproofing on the floor.
A slider also works but there is also a piece that is mounted to the floor for these types of doors. They might be able to get by with double sided tape for this piece though.
Also, like John said, opening the door "out" is going to cause issues with a floor mat. The slider is a better option in that case but most people prefer to swing the door in and it works just fine.
Name:  Wedi LIgno Shower.jpg
James Upton
Tired of bullnose tile trim? Here are 5 edge trim alternatives ~DIYTileGuy
Unread 10-04-2020, 11:12 AM   #6
I think swinging the door in is contrary to code, the idea being to be able to hit the door and exit in case of scalding water.
Unread 10-04-2020, 11:23 AM   #7
A speed bump was mentioned. That's what I sometimes do on curbless showers. Then the door will swing over a bath mat. Here are a couple.
Unread 10-04-2020, 03:42 PM   #8
A shower door can swing both ways, but not only in...in an emergency, they may not be able to get into the shower to help you if it only swings in...both in and out could work, but keeping it centered at the mid point is sometimes an issue.
TO help with water containment, Schluter does make a tiled in flexible profile.
Kerdi shower kit and framing for shower doors? awsmolak Tile Forum/Advice Board 12 06-13-2014 10:37 PM
Masonary Shower Curb and Glass Shower Doors rmateyko Tile Forum/Advice Board 18 02-16-2011 12:21 AM
Steam Shower Doors For A Steam Shower Or Regular Shower Doors? it's beer thirty Tile Forum/Advice Board 1 08-05-2007 09:26 PM
Installing shower doors on porcelain tiled shower RKEnnis Tile Forum/Advice Board 3 04-11-2007 09:08 PM
Textured Shower doors versus Clear Doors dcousins Tile Forum/Advice Board 15 12-22-2006 02:36 PM
