Unread 04-13-2010, 07:43 PM   #1
MNTileGuy
Central Texas Tile Guy
Flood Test Question
This involves the kerdi shower that's brought me so much joy...
At the request of the HO, I did a flood test. I waited until 72 hours after installing the kerdi on the pan per instructions. Filled it with water Saturday am and marked the water level in several areas.
Come back this morning and the water is roughly 1/8" below the marks. Do I have a leak? Evaporation? A little water sneaking down the drain?
Since its been 3 days, I'm hoping it's just evaoporation, but your thoughts would be appreciated.
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Unread 04-13-2010, 07:51 PM   #2
dhagin
Schluter says 24 hrs from setting kerdi to start of flood test, minimum. Flood test is 24 hrs. 1/8 in 3 days would be imperceptible difference after 24 hrs, I'd say good to go.
That much could have evaporated... has there been any penetration at seams?
dana
Unread 04-13-2010, 08:11 PM   #3
after that long I am thinking evaporation too
Unread 04-13-2010, 08:12 PM   #4
MNTileGuy
That's what I was hoping to hear!
Oops, I guess I misunderstood the 72 hour thing. Overkill on cure time can't hurt though!
The only reason I let it sit 3 days is that I wasn't working anywhere close until today. Really put it to the test!
Brad Bressler
Unread 04-13-2010, 10:34 PM   #5
Steve C
Steve C's Avatar
When I flood tested the one I built over the winter, I used a 2" test plug (rubber with a bolt to draw it up real snug) to eliminate any chance of it leaking. Worth a few bucks to be sure, and I can use it again.
Steve
Steve C is offline   Reply With Quote
Unread 04-14-2010, 04:02 AM   #6
opiethetileman
opiethetileman's Avatar
you can use a flood plub that pumps with a bycyile pump
opiethetileman is offline   Reply With Quote
Unread 04-14-2010, 04:55 PM   #7
MNTileGuy
I did use the 2" inflatable ball with a foot pump. Maybe I didn't get it full enough?
Sounds like the general consensus here is that 1/8" drop over 3 days time isn't something to worry about as there's alot of possible explanations.
Brad Bressler
Unread 04-14-2010, 05:20 PM   #8
If you lost only 1/8" in water depth to evaporation in conditioned space over three days, Brad, I'd be looking for a water leak.
A leak into your shower pan.
Unread 04-14-2010, 05:45 PM   #9
MNTileGuy
cx-
Don't me messin with me here! Had enough headaches with this kerdi business!
Brad Bressler
Unread 04-14-2010, 07:25 PM   #10
Hammy
Hammy's Avatar
If it is a conditioned space with A/C running you could loose that much in 3 days in my opinion, but what do I know............. Hammy
Kitchen & Bath Makeovers
T & J Construction Services
Manchester, TN 37355
Unread 04-15-2010, 04:33 AM   #11
opiethetileman
wonder if hydro ban will stick over kerdi....................hell brad i have stated the obvious need a technical person on site for a problem solve and cant them to call or respond...but they call brian and talk to him like they are brothers..........hey brad i saw somewhere on the forums that some one used a caulk tube and duct tape to do a flood test
when to flood test? remodel123 Tile Forum/Advice Board 8 04-04-2010 09:15 AM
Flood test for barrier free shower/wet room kellykungfu Tile Forum/Advice Board 20 03-12-2010 01:33 AM
need help with my flood test for shower pan please :) FemmeMetale Tile Forum/Advice Board 4 01-15-2010 03:53 PM
Pan test question Knyte260 Tile Forum/Advice Board 4 02-05-2006 01:12 AM
