Unread 03-18-2013, 01:33 AM   #1
jwmezzanotte
jwmezzanotte's Avatar
flood test plug
did search, and found lots of old threads on flood tests.
Did not find much of an answer on this though, what is used to plug the drain? I've read references to a balloon, plumbers bladder, tenis ball, etc.. but not sure.
Im thinking whatever is used needs to seal 100%
Can I just use a rubber sink drain plug with a flange wide enough to cover the kerdi drains I use?
I don't have weep holes to worry about.
Or is there a special tool that is for this purpose? If so, where could I find one?
Unread 03-18-2013, 03:42 AM   #2
Mr.Miyagi
Re-Remodeler & Re-Tiler
Mr.Miyagi's Avatar
I've used both inflatable and hard plugs, but prefer the inflatable type. You should be able to purchase the hard plug at any big box or hardware store and the inflatable type will probably be available at your local plumbing supply.
http://www.petersenproducts.com/130-0_pipe_plug.aspx
Cary
Mr.Miyagi is offline   Reply With Quote
Unread 03-18-2013, 04:33 AM   #3
Davestone
Florida Tile & Stone Man
I have seen them at HD and Lowes,but plumbing supply houses have them if they will sell to you.
http://Davestonestile.com
Unread 03-18-2013, 04:47 AM   #4
I have the Oatley 2" that fits into the inside of the Kerdi drain.
Unread 03-18-2013, 04:53 AM   #5
Cain
Cain
If your doing kerdi, just cover the hole and cut out when complete.
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Unread 03-18-2013, 05:25 AM   #6
HS345
Tile Contractor
HS345's Avatar
Those things can be a bear to get out sometimes, I prefer the inflatable. But I have/use both.
The name's Greg
Unread 03-18-2013, 06:54 AM   #7
Hank B.
I just use the type Brian pictured.
Hank
Hank B. is offline   Reply With Quote
Unread 03-18-2013, 07:02 AM   #8
njroadie
Test Plug
I keep a test plug like the one Brian posted in my kit for toilet waste lines during installs. After the toilet is removed, the plug gets popped into the line. I don't want sewer gas issues, and the plug helps me sleep soundly at night.
Ken
Drake Remodeling
www.Drakeremodeling.com
njroadie is offline   Reply With Quote
Unread 03-18-2013, 11:34 AM   #9
eurob
Not...Sure
Plumbing distributors have most sizes in stock.
Few plugs I have when needed.
Name:  Pipe plugs JB 002.jpg
Roberto
Unread 03-18-2013, 04:26 PM   #10
Giuseppex
Brian's, post 4 is what I use here on the west. Home depot, under $5.
Giuseppe
Giuseppex is offline   Reply With Quote
Unread 03-18-2013, 04:37 PM   #11
Plumbing inspectors like to see the balloons.
Unread 03-18-2013, 04:39 PM   #12
irish tileguy in michigan
Tile Contractor -- S.E. Michigan
irish tileguy in michigan's Avatar
I use the inflatible like Greg showed, i have the same as Brian as well but they wont fit in the Kerdi Linear drain.
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
irish tileguy in michigan is offline   Reply With Quote
Unread 03-18-2013, 04:39 PM   #13
i need a terlit plug dont know the size though
Unread 03-18-2013, 04:42 PM   #14
We carry a 4" KO knock out / test cap (very thin plastic plug) on the rare occasion we need one. It also makes a handy template for cutting holes.
Unread 03-18-2013, 05:05 PM   #15
K_Tile
Member of Million SF Club!!
One Chipolte Burrito!
Failed flood test bayne Tile Forum/Advice Board 13 09-23-2012 09:10 PM
Kerdi Flood Test Tucker Tile Forum/Advice Board 13 12-26-2011 03:27 PM
Flood Test Question MNTileGuy Professionals' Hangout 10 04-15-2010 04:33 AM
when to flood test? remodel123 Tile Forum/Advice Board 8 04-04-2010 09:15 AM
How to plug the drain to test the pan? Leigh Tile Forum/Advice Board 15 03-19-2002 08:48 AM
