Unread 06-22-2007, 12:02 PM   #1
Robertb
Tile backsplash above laminate backsplash
Hi Robert from Columbus, OH here.
I'm looking to add a tile backsplash in my kitchen, however our laminate countertops have an integrated backsplash with a curved edge on top.
Here's a rough example of it:
images.lowes*/product/048118/048118408905.jpg
(This forum won't let me post an image or link? So add a D0T COM
where the * is)
I'm not too keen to replace a perfectly good countertop (new w/ the house), but still want the tile backsplash running from the countertops to the cabinets.
From what I've read here, should I leave a slight gap (how big?) above my current laminate backsplash so the tile doesn't set on the curved edge of the integrated backsplash? What should I fill the gap with? Or should I not leave a gap?
What about cutting off the integrated backsplash from the countertops? (Sounds like more effort than it would be worth)
Your opinions would be appreciated!
BTW- I'm a newbie.
Robertb is offline   Reply With Quote
Unread 06-22-2007, 01:52 PM   #2
Dave Taylor
Dave Taylor's Avatar
I know zactly' the kinda' counter top yer' talkin’ bout' Bob and... I've seen tiled backsplashes done both ways you describe. Yer' right.... cuttin' the integrated backsplash off and coverin' the resulting exposed substrate is a pain.
I'll give you a vote of “yes” for tiling above the integrated backsplash.
Leave the first course above the curved counter top high by the same width you've selected for a field grout line.... and calk it when the job is finished.
Dave T (DIY'er)
the net.
Unread 06-22-2007, 02:28 PM   #3
ddmoit
ddmoit's Avatar
What Dave said - and it will look just fine that way.
Dan - a DIYer in SE Tennessee
Unread 06-22-2007, 09:20 PM   #4
Robertb
Sounds good. Thanks!
Unread 06-23-2007, 07:12 PM   #5
Alto
When you caulk the joint between the backsplash and the tile try and find a color-matched silicone caulk. Formica countertops usually have a particleboard base, and can expand in length 3/8" over 10' in response to temperature and humidity changes. I've had several callbacks concerning tearing and crumbling caulk when I used a siliconised acrylic caulking. I have zero callbacks with the silicone.
Indianapolis bathroom remodeling
www.iwantanewbathroom.com
Rick
Alto is offline   Reply With Quote
