Unread 03-28-2011, 04:08 AM   #1
chardscapes
Epoxy Grout ??
Hey guys. I just finished my master bath remodel. I want the best stain protection for grout. I have heard horror stories about expoxy and polyurethane grouts drying fats and the residue not cleaning off of the tile. What are your thoughts ?
chardscapes is offline   Reply With Quote
Unread 03-28-2011, 06:37 AM   #2
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Hello Chardscapes,
Yes, the working time for either epoxy or urethane grouts is limited. The key is in smaller batches which you have confidence in being able to clean up completely in the allowed period. Reading and following the manufacturer's instructions is key here. If you can do that, you shouldn't have any problems working over ceramic or smooth porcelain. Textured porcelain tiles can present some difficulties in cleaning, but it's not insurmountable. I don't understand why people use epoxy or urethane grouts with natural stone though, as the tiles still need to be sealed and there is risk of staining the stone. You should never use either epoxy or urethane grouts with frosted or matte-finish glass tiles as both grouts will affect the finish badly.
Best of luck,
Shaughnn
Unread 03-28-2011, 06:40 AM   #3
What Shaughnn said,
We use a kitchen timer to keep us on track with epoxy grouts. The new epoxies are much friendlier than the older ones.
Have help when working the epoxy, at least to clean your sponges.
Make smaller batches
Unread 03-28-2011, 08:57 AM   #4
WendyHMN
Amateur Jack of All Trades
WendyHMN's Avatar
As a noob I haven't had any issues using epoxy grout, aside from becoming allergic to it (wear gloves). My non-allergic spouse can apply a mini size on walls or more on a floor in the allowed hour. Epoxy is different from cement in the way it sets up. Cement stays soft but gets progressively less sticky. Epoxy just gets stiffer and stiffer until it's impossible to work. There's a good chance you'll have a little residue even after cleaning. On our glazed textured porcelain (has pits but they are smooth), I just use a scrubby with vinegar water and a putty knife to perfect the finish. This scrub and scrape will even work on residue you notice after a few weeks. Don't ask me how I know.
Wendy
Unread 03-28-2011, 10:31 AM   #5
vrusso123
N. E. Ohio tile-setter
a pinch of automatic dish washing detergent in your cleanup water works unbelievably well. works as a surfacant (makes water wetter).
vincent
http://russotile.com
"just keep stickin' 'em" - Pat Reagan
vrusso123 is offline   Reply With Quote
Unread 03-29-2011, 05:21 AM   #6
chardscapes
Thanks all. So is this the best way to go for stain protection is to us one of these grouts? I have an all tile shower and wat to make sure the grout stays nice.
Unread 03-29-2011, 09:41 PM   #7
sandbagger
sandbagger's Avatar
There's a very long thread somewhere on SpectraLock that covers just about everything you can imagine. Other shorter threads as well. This noobie did SpectraLock on a shower and vanity with no problems. In fact the results look better than my Portland jobs. Have at it.
-art-
__________________________
Patrick Henry
Unread 04-22-2011, 06:50 AM   #8
chardscapes
Epoxy grout
CEG-LITE vs Spectralok. Which one is easier or better ?
Unread 04-22-2011, 07:04 AM   #9
jondon
jondon's Avatar
per Custom Building Products Specs:
CEG-Lite is formulated with the same recycled content found in Custom’s other lightweight setting materials, making it the first 100 percent solids epoxy grout that contributes to LEED certification based on recycled content, which also affects the handling of the product, giving a smoorther consistency providing increased spread ability.
CEG-Lite is fairly new while SpectraLock has been around a long time and has been improved along the way. Don't know if you are a DIYer or Pro but we have many DIYers here who have used SpectraLock successfully, they followed directions!
One thing I will say in favor of Custom Building thinsets is I do like they're lightweight thinsets. So if this grout is formulated along the same way a thinking using recycled material then it may be easier to spread. We are going the route of everything being lightweight, cement board to Polystyrene for ease of installation. So Custom is following in those footsteps of lightweight technology, less fatigue trowel. You use a trowel enuf, you'll know what that means....good luck
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 04-22-2011, 09:12 AM   #10
chardscapes
I am a DIY'er . Do I use a special float ?
Unread 04-22-2011, 10:10 AM   #11
tileguynky
You want to use an epoxy float. They are generally stiffer than a regular float. The stiffer float works great with the sticky epoxy. Allows you to clean more off the tile during the application process. If you have never worked with epoxy, make a sample board with some if the scraps trying to create the same size joints as the shower tile. After the board dries, stand it up and practice with the epoxy grout. You can buy a mini kit of Spectralock at most Lowe's for about $25. It will be money well spent. Also do a search on Spectralock and find the never ending thread. Read it through for a lot of great tips and tricks.
Posted via Mobile Device
Unread 04-22-2011, 10:11 AM   #12
BronsonB
For epoxy grouts, there are special floats that are needed. They should be marked as epoxy floats. Mine had a hard green float area, and I think it was in the $8 - $10 range. I also bought an epoxy margin float. If you're having to grout walls, I think the margin float might make things easier. Just make sure it's not a soft spongey float.
Bronson
Marietta, GA
BronsonB is offline   Reply With Quote
Unread 04-22-2011, 12:12 PM   #13
Gukki
We are noobies too and got very good results with Spectralock.
We started out with an epoxy float, we had some plastic joint knifes lying about, used them to pick up dropped epoxy, and ended up using these joint knives exclusively to apply the grout. They worked great for us. Less droppings!
Also, we took Wendy's advice on her thread and taped plastic "bibs" under the area to be grouted. Picking up dropped grout from there instead off the dirty floor saved our backs and let us use up the last little bit of this $$$ grout, almost no waste.
~~~~ellie~~~~
You can see my finished hall bathroom here
Gukki is offline   Reply With Quote
Unread 04-22-2011, 02:53 PM   #14
HomeDepotAssociate
HomeDepotAssociate's Avatar
Not even trying to be nitpicky here, but I legitimately thought you were referring to some sort of chemical, "fats", that maybe existed on the tile that doesnt ordinarily dry with non-epoxy grout
and had a good giggle once i realized the sillyness in my overthinking
Kontorsion
(Chate')
HomeDepotAssociate is offline   Reply With Quote
Unread 04-22-2011, 02:59 PM   #15
it was a typo.......... Fats = FAST
TEC AccuColor EFX Epoxy Special Effects 3 part epoxy grout Soup2Nuts Tile Forum/Advice Board 22 10-16-2010 09:51 PM
spectralock mini epoxy grout - 1/16" grout lines zoomzoom3 Tile Forum/Advice Board 7 11-05-2008 11:36 AM
epoxy vs non-epoxy grout marksmith Professionals' Hangout 1 07-05-2006 12:27 PM
Mapei Epoxy or Spectralock Epoxy Grout? scorleo Tile Forum/Advice Board 3 06-04-2006 08:37 AM
Modified Epoxy Grout vs. 100% Solids Epoxy Grout dmorian Tile Forum/Advice Board 8 03-08-2006 09:12 AM
