Unread 03-04-2009, 05:45 PM   #1
anotherjohn
How to handle framing-concrete transition
Awesome forum you folks have here! I've learned a ton lurking and reading for a while, but I've got a specific item I'd like to ask about.
I'm re-doing our bathroom and laundry room, and intend to tile the floors. The laundry is about 7x12 ft, and 2/3 of it has a new framed floor over crawlspace that should be about L/720. The other third is on top of a concrete slab. It's elevated on concrete walls that are filled with rock and soil. I believe it was poured in the late 1960's. I'd like to tile continuously across the transition, but intuition tells me the two foundation systems will move differently and bad things will happen.
My solution was to solidify the transition by setting the last joist in mortar, providing it with the full support of the concrete structure. It's got a layer of 15 lb felt between it and the mortar so it won't be subject to (much) moisture-related movement, and it's PT so I won't have to worry about termites if it is a tad damp. I haven't decided on a tile underlayment yet, but I'm leaning toward 1/4" DensGuard or Ditra membrane as I have a thing for vapor barriers. I attached a drawing showing the situation.
Now that I've installed it... What do you folks think? Will the PT joist shrink and swell and move the joint vertically enough to be a problem? Should I just cut the tile at the edge of the plywood decking and put in a mini expansion joint instead of grout? (I would plan for a regular grout line there, and fill it with something flexible, but my wife wants a diagonal layout) Will Ditra give the tile more resistance to this kind of movement so I can do solid tile? Can I run underlayment continuously across the transition under the tile, or does an expansion joint go all the way down?
-John
anotherjohn is offline   Reply With Quote
Unread 03-04-2009, 06:07 PM   #2
Welcome, John.
You're gonna hafta honor that transition up through your tile surface or it's quite likely to make a joint for you, whether it aligns with your spouse's desired grout joints or not.
No, you should put a real expansion joint there instead.
Yes, it most certainly will.
That would be treated as an expansion joint and even Ditra would be separated at the joint. But you'd wanna rely upon the installation instructions of the manufacturer of whatever substrate you choose.
Unread 03-04-2009, 07:22 PM   #3
The Kid
The Kid's Avatar
Hello fellow Portlander, I would personally do it this way myself. Might as well do it right the rirst time eh! also I dont think its going to look to terribly bad if you have that profile running through a diagonal field, or you could lay over the joint and replace tiles every season. choice is up to you.
http://www.schluter.com/4_6_dilex_bwb.aspx
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Unread 03-04-2009, 07:36 PM   #4
anotherjohn
Wow, helpful and QUICK you folks are. Yeah, I think I knew that was going to be the answer.
I love it when I go out on the web and wind up talking to a local. Can you aim me at a store around here that stocks those Schluter transition pieces? The big orange one has Ditra, but not much else that I could see.
-John
Unread 03-04-2009, 07:37 PM   #5
The Kid
The Kid's Avatar
John, Not many of em will without a contractors license and some have to be ordered. Might try OTM or United Tile
Jeremy
tile over concrete to plywood floor transition? kperkins411@hotmail.com Tile Forum/Advice Board 2 11-24-2007 04:58 PM
Transition from slate to a stained concrete floor Jesuslivz Tile Forum/Advice Board 3 11-24-2007 10:16 AM
Concrete Wall Transition To Studs garman Tile Forum/Advice Board 5 10-24-2006 05:41 PM
Concrete - Plywood Tile Transition KCTileSet Tile Forum/Advice Board 1 10-15-2006 06:15 PM
Tub framing/concrete board disaster? Images attached. libbe Tile Forum/Advice Board 5 05-13-2006 10:41 AM
