Unread 02-19-2021, 02:39 PM   #1
cbohaker
Grout question
Hello, I have a question about the grout line at the top of a shower bench where the sides meet the top. Should this be caulked or grouted? Again this is the grout line that connects the top tiles to the side tiles. Thanks again for your help!
Christopher
cbohaker is offline   Reply With Quote
Unread 02-19-2021, 02:58 PM   #2
Lazarus
Lazarus's Avatar
Should be caulked with silicone. It is a "Change of plane..."
Laz...
Unread 02-19-2021, 03:08 PM   #3
cbohaker
Thank goodness.. I didn't want to have to buy another bag of sanded grout to use a little bit. I have the MAPEI caulk so Ill fill it in nicely along with all corners of the shower.
I know this is a 50/50 topic but sealing the grout I am thinking about skipping so moisture can evaporate and wont be trapped. Thoughts? I feel like if I clean the shower once a week and keep my fan on a 10 min switch after each shower any moisture should mostly be removed from the environment. Maybe even crack the window to draw in fresh air during showers? Also, is there a shelf life for grout? Thanks for the input Lazarus.
-Chris
Christopher
Unread 02-20-2021, 08:48 AM   #4
Chris, sealing the grout won't prevent it from absorbing water, though it may take it a bit longer to do so. Sealers aren't permanent, either, would have to be reapplied regularly.
Letting the fan run helps, but it takes a lot longer than 10-15 minutes for water to evaporate off all the surfaces. Cracking a window might help if the bathroom door is closed, probably not all that helpful if the door is open. If the shower has a door, or even a curtain, leaving it open will help.
Using a squeegee, and even a hand towel for the corners, will likely be your best defense, and will probably stretch cleaning intervals out quite a bit. I squeegee mine after each use, including the floor, takes me about 4 minutes. In the almost 1.5 years since put into service I've had to clean the floor only 3 times, never the walls, except for the niche. The shower has no door and I let the fan run for 60 minutes (probably over-kill).
Squeegeeing is zero fun, natch, but the upside is the shower is pretty much always clean, and it honestly looks like it was just installed.
Grout Question MaryLee Tile Forum/Advice Board 13 08-20-2009 03:31 AM
Grout Question-Thanks for help DallasSooner Tile Forum/Advice Board 7 08-17-2009 06:02 PM
White tile Brown Grout - Haze and grout question Birmingham Boys Tile Forum/Advice Board 7 05-02-2006 05:20 PM
Grout Question-unglazed white 1" hexagon tile w/black grout jburrows500 Tile Forum/Advice Board 6 12-05-2005 09:32 PM
Grout question and Backsplash EDGING question BarbFreda Tile Forum/Advice Board 15 05-24-2003 04:16 PM
