SLC's are a little runnier than pancake batter, but will leave a rolled edge unless you spread it to a feather edge. You do not have a lot of time - mix it well, pour it out and do what you need to with it. At the depth you are talking about, I'd want to spread it around, feather the edge, then leave it alone. Because of the thickness, if you aren't careful, you'll end up with it thicker over the high areas if you don't move it a little. Think of honey - it will dome a little because of surface tension. But, if you spread it over the thin areas, you can get it to level quite well. The thicker the stuff is and the quicker you put it down, the less problem. It gets easier the thicker you apply it to flood the area. If you use cold water, you'll get a little more time, but you want to be done futzing with it in less than 10-minutes after you start to mix it up or you'll run into it starting to set - think of a puddle that is just starting to freeze over - you walk through, and you end up with ragged surface rather than a nice flat smooth one.
Just have a good idea what you need to do, have all the tools handy so there are no delays, then let it do its thing and you should be fine. A flat board or piece of plywood with a factory edge should be fine to help spread, and a trowel to feather the edges.
