Unread 01-11-2007, 12:24 PM   #1
dcousins
new "tract neighborhood" house tile specs
i am shopping around for a house in NC. Hubby has an offer to move back. My friend lives in a Dr. Horton neighborhood. Never been too impressed by the builder, but I like the neighborhood and the schools. I am asking a lot of questions. I asked about the tile work in the floors and showers: Here is what I got back. It looks like the butt the tile to the base molding and do not use anything behind the shower backboard or ontop of it for waterproofing. Since my shower is a kerdi shower, I am not sure if what they are doing for the shower floor is correct? any thoughts? I could always have them use a shower pan and acrylic walls and then do tile later for less money. tile showers are an upgrade:
1. The thin-set that is used is Versabond with latex. It is used under the backer-board and under the tile.
2. We use Durarock backer-board and the manufacture recommends nailing or screwing the backer-board. Most of the time it is nailed using galvanized roofing nails.
3. The tile is butted to the base molding and then shoe mold is installed over the tile at the base molding. The shoe mold is then caulked to the tile floor. The expansion gap is not really necessary with the tile because of the limited amount of expansion or contraction that would take place with the tile. An expansion gap of approximately 1/8" is left between the base molding and hardwoods to allow the wood to expand and contract as needed.
4. The tile shower would be waterproofed in the following manner:
1. A rubber membrane is installed by the plumber on the floor and tested for water tightness at the time of our rough-in inspection with the Town of Morrisville.
2. The tile installer uses thick bed mortar on top of the membrane to shape the floor of the shower so it will drain.
3. The tile is installed on top of the thick bed mortar using the Versabond.
4. Durarock is installed on the walls. The joints are taped and sealed with thin-set and then the wall tile are installed.
DC
dcousins is offline   Reply With Quote
Unread 01-11-2007, 12:36 PM   #2
TheBalls
From their description, they simply lay the liner on the floor and then form the "preslope" into the shower bed. That would be the wrong way to build it.
Scooter
TheBalls is offline   Reply With Quote
Unread 01-12-2007, 10:39 AM   #3
dcousins
so, should I move on to another neighborhood or just forgo the tile until later.
there is a really good builder in that area called Gail Crabtree but I am almost afraid to ask about her showers although if someone were to do them the right way, it would be her:
http://www.gcrabtreehomebuilding.com/
example of her work:
http://www.gcrabtreehomebuilding.com/ValleyMeadow.html
she is kind of expensive and only builds in the boonies, but tile in baths and oak floors downstairs are standard.
DC
Unread 01-12-2007, 01:05 PM   #4
frankpc
Deborah,
Hey - We live in Raleigh and are in the middle of having two bathrooms tiled. Had to look long and hard to find a sub who would work with us on the details but we have one. Be glad to pass along his contact info if you would like.
During the last Parade of Homes here we went through many high end homes. Most of the work did not have the attention to detail we would have wanted.
Of course, I only knew that from reading here ...
Frank
frankpc is offline   Reply With Quote
