11-20-2022, 03:46 PM
#31
Epoxy can help with keeping grout from cracking in change-of-planes. There are a few instances that I use epoxy instead of silicone. But I know that it's in conflict with industry standards and, as CX says, "the use of the epoxy grout could make the situation either better or worse."
11-20-2022, 11:56 PM
#32
And in some cases, the extremely strong tensile strength of the epoxy grout used in the change-of-planes has resulted in cracked tile.
11-21-2022, 08:04 AM
#33
So in that case if I epoxy my shower floor I would not use epoxy on the change of plane (and even on bench change of plane?)
Tom
11-21-2022, 12:55 PM
#34
I wouldn't, and didn't, Tom. I caulked all the changes of plane except in the niche.
11-23-2022, 12:20 PM
#35
This is the main area where I stray from the industry guidelines with epoxy grout.
I would epoxy the shower floor, the perimeter joint, the outside corner on the bench joint if it's mitered, and the shower curb if I still have enough and it's the same color.
11-23-2022, 02:23 PM
#36
Tom, I've moved your posts from the very old general discussion in the Hangout to your shower project thread to avoid confusion both places. A moderator can give this thread a more generic title any time you'd like to suggest one.
And you can see there are differing opinions on the subject of grouting your shower floor with epoxy. I would not recommend epoxy grout on any shower floor at all, regardless how you elect to treat the change of plane areas.
11-24-2022, 03:11 PM
#37
tile to wall or to spacer on corners
I am getting ready to tile my back wall in shower. these pics are of back wall and shower wall vertical joint. In pic 1 I have spacers in pic 2 I do not. Since I am doing back wall fisrt and it will be buried by side wall tiles, do I use spacers or not. As well, am I correct that the buried joint will not need grout or caulk and the joint that ends up above the buried joint is where I will caulk?
Tom
11-24-2022, 05:30 PM
#38
Senior Contributor
You don't want any tile to butt up against a rigid surface.
My preference is to use a profile in a corner as it negates any need for caulk there, provides a nice straight edge that can hide most inconsistencies, and provide the necessary movement joint the industry calls for in changes of plane or materials. I'd put the pocket on the long wall and from the entry, it's hard to see the other edge. These come in numerous thicknesses and colors to account for various tile options.
Caulk will work too.
11-24-2022, 06:39 PM
#39
Tom, you never want the edges of your tiles butted against anything, including other tiles. The object in leaving space between your back wall tiles and the end walls of your shower is to provide movement accommodation. You needn't fill those particular gaps with anything.
The object in leaving spaces between your wall tiles and perpendicular wall tiles is also movement accommodation. Filling those particular gaps is an aesthetic consideration; filling them with something that still provided movement accommodation is a technical requirement.
And while it may seem a minor point, you do not want to use a caulk in any such places. You want to use a flexible sealant. The caulk will not necessarily allow for movement, the sealant will.
11-24-2022, 07:10 PM
#40
Got it...thanks!
Tom
12-29-2022, 10:48 AM
#41
Tile Placement
I am wondering if I should put tile in before or after the granite shelf on both the back wall and side wall - see pic
Tom
12-29-2022, 10:56 AM
#42
Dealer's choice. I'd likely choose after.
My opinioin; worth price charged.
12-29-2022, 12:08 PM
#43
Would you also do granite after on bench and curb?
Tom
12-29-2022, 01:05 PM
#44
Probably. But not my shower, eh?
12-31-2022, 05:30 PM
#45
Before: Bench, shelf
After: curb
This forum makes images as confusing as possible. Post 37 is upright or sideways? What's going on with 43?
