Unread 07-27-2013, 12:39 PM   #1
aaron0593
Honed bianco venatino marble
Hi. Anyone have advice about installing this marble?
It is really absorbing water, trying to upload pics. Would this then be considered a moisture sensitive stone? For which I would need epoxy mortar
I was thinking of using white ardex x5 but have been told to use x32. It's over ditra.
Also. There is a bevel. Do you normally fill the bevel or clean the grout out? Looks like I need a 1/16 inch grout joint because they are not 100% square.
Aaron
aaron0593 is offline   Reply With Quote
Unread 07-27-2013, 04:43 PM   #2
Ken
welchtile.com
Aaron,
I'm not much of a stone person, so I'll shoot off a private message to a member who is and hopefully they can help you out.
Ken
Ken is offline   Reply With Quote
Unread 07-28-2013, 05:09 AM   #3
Davestone
Florida Tile & Stone Man
It is basically a Carrera,from the same quarry just classified differently by appearance,or supposedly it is.I would treat it as such,it should not warp,BUT,you never know these days.Put a piece in a pan of water and see if it does.
http://Davestonestile.com
Unread 07-28-2013, 02:01 PM   #4
MDtile
I think some call it "Nantes", not sure though.
MDtile is offline   Reply With Quote
Unread 07-28-2013, 06:14 PM   #5
aaron0593
thankyou
I will try the pan test, thanks.
how about the grout joint
Aaron
How would you seal and then maintain White Bianco Carrara Honed Tile in a shower? SenecaC Cleaning, Restoration and Sealing 0 06-27-2012 09:21 AM
setting honed marble bill blackwell Tile Forum/Advice Board 4 03-02-2011 08:27 AM
restoring honed marble mazi Cleaning, Restoration and Sealing 3 01-06-2010 10:17 AM
Do I have to seal honed marble? Waltgphd Tile Forum/Advice Board 2 06-06-2008 02:57 PM
Honed marble matman Cleaning, Restoration and Sealing 9 07-29-2007 11:05 PM
